Rusted Drip Rails
I have a 67 and the drip rails are pretty rusted. how difficult is it to replace them? I have done a search and there is not alot specifically about replacing the drip rails, mostly just shaving them.
If I do shave them I have seen where some people have left a small lip and others have shaved completely off, which is the better option? |
![]() ![]() Join Date: Jul 2002
Re: Rusted Drip Rails
I did a section of mine (starts at post 54)
https://67-72chevytrucks.com/vboard/...=825127&page=3 Took a lot of sanding, spot weld cutting, and chiseling to remove the bad section. The parts are available, so I got one (at the time I found the last one in the states for above drivers door) (Used American Metal Direct). I have heard some folks have issues with the replacement pieces not being long enough, but I cut the new piece and only used what I needed. I used a 3m bonding adhesive rather than welding since it wasn't super structural and I didn't want to chance warping it. I did one small tack weld to join the 2 sections and JB Welded the seam. Mine was above the door, but I imagine it can be done that way across the windshield area also. Make sure you use a good seam sealer afterwards. To keep the water from getting in again.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-12-2023 at 06:12 PM. |
great, thanks for the post with pics. it helps alot.
| Bookmarks |
