Old 01-12-2023, 01:25 PM   #1
C10 - C90 Bill
C10 - C90 Bill's Avatar
'72 C-10 307 Water Temp Sending Unit
On a '72 C-10 307 V-8, from the factory for a Water Temp Sending Unit for an Idiot Light, did it have 1 Prong or two?
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 01-12-2023, 02:05 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: '72 C-10 307 Water Temp Sending Unit
First picture is sender for gauge, second is for light.
LockDoc
Leon
Old 01-12-2023, 03:10 PM   #3
C10 - C90 Bill
Great pictures, thanks.
Bottom one is exactly what I need. Was having trouble finding one.
GMC 9500 Fan
Detroit Diesel Fan
Old 01-12-2023, 10:14 PM   #4
tutone
tutone's Avatar
Not sure about the teflon tape on it though. I think the metal to metal is your ground.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1969 C10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 01-12-2023, 11:43 PM   #5
dmjlambert
dmjlambert's Avatar
I believe a couple of wraps of teflon tape is OK. Enough of the metal will cut through the tape and make good ground contact.
The temperature switch is Wells or AutoZone part number is TU51 if the hole where you are putting it is threaded for 1/2 NPT size, and TU78 if the hole is threaded for 3/8 NPT.
TU51 turns on at 251 F +/- 10 degrees, and TU78 turns on at 240 F +/- 10 degrees.
dmjlambert is offline   Reply With Quote
Old 01-13-2023, 09:40 AM   #6
C10 - C90 Bill
Appreciate the additional replies.
GMC 9500 Fan
Detroit Diesel Fan
Old 01-13-2023, 11:26 AM   #7
Accelo
Accelo's Avatar
GM didn't want annoyance activation of the overheating lamp did they?
240 might be OK. Definitely pass on the 250 deg switch.
Considering even the lower temp switch is 6O deg over what the design temperature.
I am unsure where the switches were manufactured but I am not a fan of the overseas temperature anything. I have been burnt bad by them. I only use them when I have no other choice. Then I check them against the factory resistance and temperature. They are typically way off. I have been able to correct them by adding resistance to the feed wire. Since most of our truck use gauges OEM the OEM switches can be picked up for little money on ebay.
https://www.ebay.com/itm/28488051378...Bk9SR4jczbu1YQ
This one is $15 and free shipping.
Others for as little as $8.
Here is the search terms I used. Copy it with the brackets. (6490128,6490793)
I believe the part numbers are correct, possibly somebody will confirm.
BTW the Teflon tape, shown on the switch, is installed by the manufacture.
GM didn't do this and doesn't recommend installing tape. Just an indicator of how much research they put into their parts.
I also agree it likely will not typically make a difference on the grounding. However, I don't use tape and never had one leak.
Cheers
Accelo is offline   Reply With Quote
Old 01-13-2023, 01:27 PM   #8
C10 - C90 Bill
Update: Still having trouble finding the correct one. When I went to Rock Auto it only showed a 2 Prong for my application. Also when I typed in both TU51 and TU78 at Autozone, it stated "Does Not Fit Your Truck" ('72 C-10 307 V-8)
GMC 9500 Fan
Detroit Diesel Fan
Old 01-13-2023, 01:56 PM   #9
LockDoc
LockDoc's Avatar
Does your temp sender wire have one connector or 2? What size are the threads on the sender, 3/8's or 1/2 inch? I am presuming you have the indicator light dash and not gauges.
LockDoc
Leon
Old 01-13-2023, 02:03 PM   #10
kev2809
low n' slo
kev2809's Avatar
you have to be careful with rockauto and even the auto parts stores. rockauto listed a temp sender for my truck and it was no where near the correct range...even though it listed as correct, and it was the only one they showed. i would second the comment above about ebay. only search for the part number instead of what fits your year model, they arent always correct.
and x3 on the tape, i didnt use any on my threads and not a single drop comes through
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-13-2023, 03:26 PM   #11
C10 - C90 Bill
LockDoc
1 Prong. That's why when you posted a picture of the 1 Prong for a Light, which is what I have, I figured that that be the correct one, but I can't find the Part Number for it. Not sure on the Threads yet, but most applications show just one. Although they either have 2 Prongs or a Round Prong for a Gauge application. No luck on a 1 Prong. Believe GM may have given me an out-of-the-ordinary set up.
GMC 9500 Fan
Detroit Diesel Fan
Old 01-13-2023, 03:29 PM   #12
C10 - C90 Bill
Maybe the TU51/TU78 from Autozone will work??
GMC 9500 Fan
Detroit Diesel Fan
Old 01-13-2023, 04:04 PM   #13
LockDoc
LockDoc's Avatar
Look at this one....
https://www.classicindustries.com/pr...arts/tu45.html
LockDoc
Leon
Old 01-13-2023, 05:34 PM   #14
OregonNed
OregonNed's Avatar
I was very happy with the one I purchased from Lectric Limited - but it was $25
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 01-13-2023, 09:36 PM   #15
dmjlambert
dmjlambert's Avatar
I think Autozone's fitment data is probably lacking accuracy. TU51 does fit a 1969 C-10, and Autozone's website also says that. When you click the link on Autozone that is for showing the switch that fits 1972, it sends you to parts that are listed as switches, but just looking at them it is apparent they are gauge sensors and not switches. (edit: apparent to me because of the terminal shape and comments people have left that indicate they are working with gauge clusters, but I would have to test one with an ohm meter to be sure)
I think a switch that switches on at a desirable warning temperature will work with a 67-72 instrument cluster with warning lights. The light is either on or off, so the thing that will make a difference is what NPT size hole is in the engine head. The TU78 part is for 1982-89 Chevy truck and is suitable for an older truck if your older truck has 3/8 NPT hole in the head because the engine was refreshed with an engine or engine heads that are newer and have the smaller hole, like mine. I have the original 1969 engine with 1992 heads on it, so the hole is 3/8 NPT. I researched it for my truck and posted here what I found: http://67-72chevytrucks.com/vboard/s...d.php?t=726025
If you want to have high confidence I think it is necessary to put a coffee can of antifreeze and water mixture on a stove or outdoor propane cooktop and put a candy thermometer and the switch in the mixture connected to an continuity tester or test light, and verify at what temperature it switches on.
Old 01-13-2023, 09:45 PM   #16
dmjlambert
dmjlambert's Avatar
I'm sorry I didn't give the whole story and link to my research in my first reply. I thought it may be too much to read, but then again everybody needs a certain degree of confidence when outfitting a truck.
Old 01-13-2023, 11:45 PM   #17
C10 - C90 Bill
Appreciate the additional replies. I now have more to check into.
GMC 9500 Fan
Detroit Diesel Fan
Old 01-14-2023, 12:08 AM   #18
cwcarpenter98
cwcarpenter98's Avatar
I purchased a sending unit for my 63 from Letric Limited. It works perfectly with my original gauge.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 01-14-2023, 12:20 AM   #19
dmjlambert
dmjlambert's Avatar
Yes, I think Letric Limited is renowned for a good sender for gauge instrument clusters, but for this thread we have been discussing warning light instrument clusters. The sender for a warning light instrument cluster is a switch with flat blade terminal.
