Old 01-05-2004, 10:33 PM   #1
GMC 3
where to get brake lines?
I am running new brake lines and I Have a 69 frame with a 78 front crossmember with discs. do I use the same brake lines I would if the 69 crossmember was still on their (assuming I leave prop. valve mounted at booster) Who has the best prices for pre bent brake lines? I need all of them
thank you
GMC 3 is offline   Reply With Quote
Old 01-05-2004, 10:41 PM   #2
1969 GMC
1969 GMC's Avatar
i am not sure about the 69 vs 78 frontends, but i would recommend getting a pair of brake line bending pliers and just buying brake line blanks at a parts store, it is probably cheaper and is very easy to do.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-05-2004, 11:29 PM   #3
Bernie
I'm doing this now on a 69 K20 with axles off a 78 K20. I was told that lines off a 71 with discs would work. They don't ! Latest advice is to get lines for the axles not for the truck.
Bernie
Bernie is offline   Reply With Quote
