Old 01-16-2023, 07:33 AM   #1
Hack71
Hack71's Avatar
71 C10 454 Engine Swap Info needed
I'm preparing for an engine swap on my 71 C10 Cheyenne long box. The truck is an original 350/TH350 with factory A/C, PS, PB, I will be swapping in a 454/TH400 from a motorhome. I want to be as prepared as possible. I've searched some posts and got some conflicting info. I want to do a budget friendly swap; my biggest concern is how the 454 will sit in the engine bay. I've heard that it depends on which engine frame mounts I use, I would like to use clam style engine mounts and frame towers from a 73 and newer, does it matter if they are from a c10, c20, c30, does it matter if they are from a SBC or a BBC, I've read that the engine could sit to far back on the firewall. I have the transmission yoke for the TH400, Will the 454/400 swap in without changing the length of the driveshaft? Currently I have a two-piece shaft. Will the trans crossmember need to be moved? my plan is to use a 19" electric fan from a Jeep Cherokee and mount it in the 71's original fan shroud. the truck has a 4-row radiator that should be sufficient. Pics are attached, any advice or info would be greatly appreciated. Thanks,
http://67-72chevytrucks.com/vboard/s...d.php?t=693490Cheyenne, AKA "Spare Change" Hack71 Build
Hack71 is offline   Reply With Quote
Old 01-16-2023, 08:36 AM   #2
D.B
D.B's Avatar
Re: 71 C10 454 Engine Swap Info needed
Keep in mind the TH400 has an electric kickdown and the TH350 is cable driven from the carb.
D.B is offline   Reply With Quote
Old 01-16-2023, 08:52 AM   #3
notsolo
notsolo's Avatar
Beautiful truck, 3 tailshafts also for the 400. Probably need driveshaft cut, I cut 3" off mine for a 4L60 swap, engine to the rear position... I think the claim shells are all the same, frame mounts different for some applications. Save the power steering big nut, flare adapter from your old setup.
notsolo is offline   Reply With Quote
Old 01-16-2023, 10:25 AM   #4
Hack71
Hack71's Avatar
Smile Re: 71 C10 454 Engine Swap Info needed
Thanks, any thoughts on retaining the TH350 behind the 454, the 454 has a mild cam, its not pushing a lot HP or torque. The TH350 is solid with a shift kit
Old 01-16-2023, 01:05 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I would not use the Jeep fan with the 454. Get a Big Block fan shroud and use a newer HD fan clutch for reverse rotation with a fan (I have a pic) and put a pusher fan on the condenser. If the TH350 is built, use it. As long as the mounts are in the V8 position you should be fine. If you put them in the 6 cyl location the HEI will hit the fire wall. Most people who convert 6cyls to 8's do not put forth the effort to move everything into the factory location and that is why you see stuff riding the firewall.
I have used the Jeep fan mod in the past.
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-16-2023, 02:54 PM   #6
HO455
HO455's Avatar
I have a destroked 455 Pontiac that has dynoed over 450 hp on several different chassis dynos and has run 11.20's at over 120 mph in a 3400 pound GTO bolted to a T350. It was properly built for this an has a 10 inch Continental converter that stalls around 2800. It's been a great transmission for over 10,000 miles.
So yes, T350's will get the job done with the proper preparation. Now towing may change the viability of a T350.
RIP Bob Parks.
Old 01-16-2023, 10:23 PM   #7
shortbedmike
your th400 will require a bolt in high hump tunnel and a little cutting, and then a new carpet for the high hump. if you stay with the th350 check the flex plate for the th350 bolt patern, a lot of the motor home used 6 bolt converters and the flex plate won't have a dual pattern. so you may need to buy a new one as the 454 is external balanced so the one on you small block won't work.
shortbedmike is offline   Reply With Quote
Old 01-16-2023, 10:51 PM   #8
lolcopter
I used the clamshell mounts. I have a 700r4 and had to slide the trans cross member back and shorten driveshaft. Photo to show how it sits in engine bay.
lolcopter is offline   Reply With Quote
