Engine shut off ?
I was puttering around on a new project (71 C10) with a 350 motor , was running like butter then I turned around to grab something out of the garage and it was like someone turned the key off ? no sputtering or rpm difference it just shut off and wouldnt re-start . Its getting fuel and has a new fuel filter . Has an HEI not points . Any Ideas ?
Re: Engine shut off ?
The HEI has a module that can go out. It’s very common, so much so that I have been known to carry a spare in the glove box. You can test it.
assuming fuel pressure is good, I suspect HEI module.
Have you confirmed you have spark OP? By chance did the choke not open if it has one?? |
![]() Join Date: Mar 2003
Put the putter back into it. You must've dropped it when you turned around.
couldn't resist |
Thanks for the advice , I will try the module.
if you replace module, use heat sink paste under it. Its $2 at AutoZone
Replaced the ignition module , still no start . Started messing around with the wires , found out the lead wire from the H.E.I. had somehow fallen out at the ignition cylinder ? plugged it back in and it fired right up ! Thanks to all those who commented and helped .
keep the old module as a spare
![]() ![]() Join Date: Jul 2002
Diagnose the problem rather than throwing parts at it.
1. Check for spark. Timing light works well 2. If no spark check for 12V at HEI dizzy. 3. If 12 v at dizzy then try ignition module
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 01-19-2023 at 11:47 PM. |
