Old 01-16-2023, 01:30 PM   #1
72c20customcamper
72c20customcamper's Avatar
Well that’s disappointing !
Took my seat apart on my 68 stepper . Got a little excited seeing the original under the recover . Back is in great shape but the seat bottom must have been ripped so they cut out the damage but on the bright side the foam is perfect . And I look at the replacement and it’s the right color but wrong . The original was embossed the new one is pleated. Not a big deal since I’m going to add carpet instead of the rubber mat. The red is because I set up my canopy in my barn . Able to heat it and not worry about snow load .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-16-2023, 03:45 PM   #2
72c20customcamper
Re: Well that’s disappointing !
Going to need some foam .Seat skin is way to loose on it I used the original little clips to hold it temporarily into the frame .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-16-2023, 04:40 PM   #3
Grumpy old man
Grumpy old man's Avatar
Go to joann fabrics and get some Dacron/ polyester padding , Allow it to roll over the edges , You can use a hair dryer / heat gun on the low setting to help ease wrinkles , Don't over heat the vinyl . if it's too hot to hold your hand in the heat it's too hot for the vinyl
https://www.joann.com/fairfield-30x1...SABEgKH0PD_BwE
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 01-16-2023, 06:05 PM   #4
72c20customcamper
Thanks . Was thinking some high density foam but that may be too much even at 3/8 thick . I use a heat gun at the lowest setting even then I move fast over the vinyl
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-16-2023, 06:08 PM   #5
72c20customcamper
Need to fix this support spring too .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-16-2023, 06:26 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
I found the proper thickness spring wire at a hobby shop in 3 foot pieces and hand bent the new springs. Mine were the ones on the edge of the seat. I think it is 3/16". Real fun to bend.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-16-2023, 06:35 PM   #7
72c20customcamper
That’s the spring the broke just one on the drivers side
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-17-2023, 10:42 PM   #8
Lost in the 60's
Lost in the 60's's Avatar
A hair dryer on high is safer than a heat gun on low. Takes a little longer, but won't overheat the vinyl.
Lost in the 60's is offline   Reply With Quote
