![]() Join Date: Nov 2018
Rear brake hose help
Can anyone recommend the best replacement rear brake hose? Take a look at the photos below. This is the replacement I ordered for my 72 Blazer. On the input side, the inner opening is bigger on the original than the replacement. And on the "T" side, the inner opening is smaller on the original compared to the replacement. The threads/fitting size is correct, but I'm wondering with the difference in opening sizes if everything will seal correctly. I've picked up two brands, and both have Sunsong stamped on the hose. Thanks!
![]() Join Date: Dec 1999
Re: Rear brake hose help
Pretty sure I've used that same sunsong hose and it worked fine. Can't comment on the different size holes. I don't think it will make a difference though, as long as the nuts seal.
![]() Join Date: Jul 2015
Difference in manufacturing techniques, a double flair will seal up just fine and your brakes will function as they should.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
