Old 01-17-2023, 04:27 PM   #1
Chaparralman1974
Chaparralman1974's Avatar
Leaf Spring Question
Good afternoon everyone!
I am to the point where I need to start working on the leaf springs in my '67 K20. I want to replace the rubber bushings, bolts, and teflon pads that sit in between the leaves. My springs are weird though. They are about 3.25" on each end and taper to 2.5" or so in the middle (I haven't measured them yet, but that is what I think they are). Are these rubber bushings even available? I was looking at LMCTruck and they list spring bushings that are for 67-72 but mine seem to be different. Can anyone verify/confirm this? If they are different, where can I get new ones?
Thanks, Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 01-17-2023, 07:31 PM   #2
roger0080
Re: Leaf Spring Question
I would try a visit to a local shop that builds/rebuilds/fixes spring packs who would or should know all about the bushings and pads, or even do it for you.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 01-17-2023, 09:06 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not sure of the exact measurements, but the original front springs on my '72 K20 were wider at the bushings and narrower in the center at the spring pads. I scrapped them years ago, bushings & all, when I installed 2.5" Softride springs. Those came with new urethane bushings. Good luck in your search, I'm sure new bushings exist. Just gotta find 'em. Roger's idea sounds like a good place to start.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-17-2023, 09:20 PM   #4
kwmech
http://www.valleyspringservice.com/
Old 01-18-2023, 12:01 PM   #5
Chaparralman1974
Thanks for all the information everyone. I just dropped them off at the local spring shop (Dunbar Springs) in Phoenix. They have been in business since 1919. I called them and the guy knew exactly what I was talking about. $85 per spring and they all get cleaned, painted, rebuilt, rearched back to spec, new center pins, new bushings, new clamp bolts for the end of the leaves, and new teflon spacers between the individual leaves. Money well spent!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 01-18-2023, 12:33 PM   #6
biketopia
That's a pretty good price. I think similar around here is a little over 100 each from the spring shop we've been dealing with for 40+ years.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 01-18-2023, 02:06 PM   #7
mjmarinara
mjmarinara's Avatar
In my rear i just plopped down $200 a side and did brand new dormans and intend to do the same up front in the spring. Springs are 50+ years old but theres always the debate if springs age or not.
I live close to SD truck spring and they do great work and they are a huge online spring distributor but I believe they stopped rebuilding springs for light trucks so I just paid for all new ones.
mjmarinara is offline   Reply With Quote
Old 01-18-2023, 03:22 PM   #8
kwmech
Clay
That's a good price for the work------good job. Show us a pic when you get them back
