Old 01-05-2004, 11:30 PM   #1
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
31X10.5X15 on a 15X8 wheel?
Okay, there seems to be a bit of conflicting information regarding the 31X10.5X15 combo on 15X8 wheels. Some folks say, "Go ahead! No problems at all!" Others say, "Hmmm... you can do it, but I don't think it's a good idea!" Still others say, "Nope! It doesn't work!"
So what's the verdict, guys? Can I shoe a 15X8 wheel with 31X10.5X15 tires? I want a fairly aggressive tire that really fills the wheel well and I don't want a goofy 20-inch, $1,000 billet wheel in there. It's a truck, dammit!
PS: No offense to those that run giant wheels and rubber band tires. You do your thing and I'll do mine!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 01-05-2004, 11:31 PM   #2
shuttermutt
While we're at it, is there a list of the factory wheels that will fit the 6-lug pattern? If I'm not mistaken, the 6-lug wheels on the 73-87 4X4s will work. Also, the 6-lug wheels on some older Nissan and newer Toyota 4X4s will fit, too. Does anyone have a complete list?
'Mutt
Old 01-05-2004, 11:34 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sure sounds like a perfect match to me! Probably more info at www.tirerack.com. General rule of thumb, tread width should be similar to (or 1" wider than) rim width. 10.50 tires go on 8" rims; 12.50 tires go on 10" rims.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-06-2004, 12:09 AM   #4
shuttermutt
Is that what you're running, Stocker? Got pics?
'Mutt
Old 01-06-2004, 12:12 AM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
One of my friends put some 31x10.50's on a set of 15x10's on his 4x4. They looked pretty ballooned on the rims....were too big for a 10" rim. I think a 8" rim would have looked much better....you should be fine
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-06-2004, 12:14 AM   #6
padreisla
padreisla's Avatar
Cool Tire/Wheel Setup
Shuttermutt, when I first bought my 67 c20 it had a set of 31X10.5X15 tires on 15X8's wheels in front and the 31X10.5X15 tires on 15X10's wheels in the back. The only reason I removed them was that I wanted a new set tire/wheel setup. I bought the truck from my brother and he used the truck for quite awhile with that setup and did not have any problems at all. I went to a different tire size, but that is because I dropped the front 3" and the back 4". As a matter of fact I still have the old tire/wheel setup as a backup option.
Joey
67 C20 LWB
454 BB
THD 400
97 Jeep Wrangler
4cyl
5sp
padreisla is offline   Reply With Quote
Old 01-06-2004, 12:43 AM   #7
shuttermutt
Cool. Sounds like the combo will work just fine from what I'm hearing. I just didn't want to do anything totally unsafe. Thanks for the input, guys. Anybody with nothing better to do than to post pics of trucks with this combo would get a big "thanks" from me. I know there's a couple of pics floating around, but I can never seem to find them again.
'Mutt
Old 01-06-2004, 12:46 AM   #8
7d14xfun
I have 31x10.5x15's BFG Long trail's mounted on Eagle 589 15x8's. Absolutley love them. No problem with fitting or rubbing whatsoever.
1971 Chevy K10 Stepside
1999 Chevy Silverado 4x4
7d14xfun is offline   Reply With Quote
Old 01-06-2004, 12:49 AM   #9
7d14xfun
Having trouble posting my pics for some reason.
Old 01-06-2004, 12:52 AM   #10
shuttermutt
Awesome! Now, does anybody care to take a stab at the second question? The steel wheels I'm running are beyond repair and can't be balanced properly. I'm hesitant to have new tires mounted on 'em and I'm very hesitant to get the living crud shook outta me on a 1,700 mile trip West in a couple of weeks.
I'd like to find a set of replacements, but the salvage yards up here won't talk to you unless you're VERY specific on what you want. Knowing what will fit could save me some time as I browse for potential replacements.
'Mutt
Old 01-06-2004, 01:46 AM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Currently running 33-12.50/16.5 tires on 9.75" rims....
No decent pics, just the avatar.
- Mike -
RIP El Jay
Old 01-06-2004, 01:57 AM   #12
Paul72
Paul72's Avatar
The K/20 had 31X10.5's on a 16.5" wheel. Might go to 33's when it's back together. My Blazer has 31X10.5's on a 15X8 wheel.
Can't seem to post pics at the moment - I'll try again later.
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 01-06-2004, 02:26 AM   #13
cheyenne10
cheyenne10's Avatar
perfect fit
My assumption is any tire store around would recommend that exact match for wheel and tire combo. I even have seen... 35x12.50x15's in 8" ralley wheels. I also have a set of 235/70/15's stretched onto 8" wheels. Quite the variety but what you want is perfect medium.
Bob
cheyenne10 is offline   Reply With Quote
Old 01-06-2004, 03:18 AM   #14
72 CustomCamper
huh ???
72 CustomCamper's Avatar
When wew bought our 84 truck new, it had 31x10.50's on 8" rims from the factory. On my toyota i'm running 31x10.50's on a 7" rim. On #2 question, Most any 6 lug wheel except for dodge 6 lugs will fit the bolt pattern. On the import wheels you might have problems with not enough backspacing if you have disk brakes...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-06-2004, 03:31 AM   #15
Rooster's 67
Rooster's 67's Avatar
73-87 chevy ralley or plain wheels off of a 4X4 fit the 6 bolt pattern perfectly.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-06-2004, 03:44 AM   #16
doughby82
doughby82's Avatar
this is off of the main page should help you out shuddermut
http://67-72chevytrucks.com/techtips/other/other_4.html
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 01-06-2004, 06:23 AM   #17
Southpa
Southpa's Avatar
I have a pic right here of my truck from 4 years back, it was right after I replaced a bedside. I tried posting the pic but error message jumped up. I'll bet everytime someone tries to post a pic Josh will get an email about it. Sorry J, I tried about 3 or 4 times, .
Anyway, the tires are 31X10.5X15 Michelins on 15X8 rims (6 lug). Good fit, no problems. When I swapped front ends 2 yrs ago (1970 drum to 1971 disc) I had to get new 5 lug rims. The guy down at Big-O Tires (won't deal w/ them again, way too pricey) said the 15X8 were out of stock and he assured me that 15X7 would be ok for my tires. I guess he was right, its been two years and there have been no problems. Inflated to about 42 lbs, no uneven wear, smooth ride.
I'll try to get my pic into this thread tomorrow.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 01-06-2004, 08:10 AM   #18
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Had an 85 blazer that came with 31-10.5R15s on 15x8 rims from the factory.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-06-2004, 09:20 AM   #19
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
On the bfgoodrich page they have 7-9 inches as a recommended size
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-06-2004, 11:13 AM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have 35x13.50's and 32x11.50 on 10 inch wheel's and the both look good.. I would say rum em..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-06-2004, 12:30 PM   #21
pickupman
pickupman's Avatar
I run 32X11.50 on all my 4wds with factory rallies. I have used this combo for 15 tears or more without any problems.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 01-06-2004, 12:52 PM   #22
fishead
Wheels and Tires
Long story made short.
I ran 15 x 8 wheels from the mid 70s on my 72 and 70 trucks. They worked fine for me.
I also ran 31x10.5x15's on said 15 x 8, 5 lugs on the 1972 C10.
No problems, and I really liked the ride and feel of the larger tires.
Go for it!
fishead is offline   Reply With Quote
Old 01-06-2004, 03:16 PM   #23
My 96 is running 31x10.50 x15 on 8" wheels. I think it is a perfect combo. I am not running on my 70 step now, but they fit just fine. No rubbing or other issues came up. It's a great combo for any truck far as I am concerned.
Old 01-06-2004, 05:07 PM   #24
Southpa
Southpa's Avatar
I forgot I had pics right here. These are from the day after I bought my tires.
http://67-72chevytrucks.com/tc1970_4.html
Original 350/TH350
Old 01-06-2004, 08:25 PM   #25
mooneyes
mooneyes's Avatar
..i had an 87 blazer with stock 8" ralleys and i put 32/11.50's on them with very little sidewall bulge
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
