01-21-2023, 02:22 PM | #1 |
A/C Bracket Help
I was wondering if any one has a possible fix. I have factory A/V on my 70, but I also have a set of Original Micky Thompson Valve covers I'd like to use. However, they are a little taller than factory and the one A/C bracket won't clear it. Anyone figured out how to get a bracket that is taller or am I stuck with factory style valve covers?
I really don't want to go pancake style cause I already have all the new stuff in the factory style.
01-21-2023, 11:14 PM | #2 |
Re: A/C Bracket Help
It looks like that bracket has a little bit of a bend in it. I wonder if you could cut a wedge-shaped notch in it in one or two places and bend it some more, and weld up the notches. Or mock up a shape using a piece of plywood, and when you find the shape that works have somebody fabric it for you or use it as a model to notch and bend the one you have.
01-22-2023, 12:56 AM | #3 |
If there's a section of just flat steel, cut completely, make up a piece to lengthen and get the right bend, tack, test fit, adjust, finish weld, grind smooth, then paint. Yeah, a little work is involved, but then you'll have something that will fit with whatever valve cover you want and still look stock to most people, except us that know.
CAD can be your friend in this situation. Cardboard Aided Design, that is
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-22-2023, 08:17 PM | #4 |
I wonder if your valve cover clearance issue is why some of those brackets have a notch in them like the one shown in this thread.
http://67-72chevytrucks.com/vboard/s...+a%2Fc+bracket |
01-23-2023, 02:36 PM | #5 | |
Nope. The "slide" bracket you got circled that goes over the valve cover wasn't hitting the valve cover but it was too long. I think the issue for me was a non-factory intake so the end that goes past the bracket on the intake was hitting the aftermarket intake. Really long story short, I simply made another one. I think if you took some flat stock and played around with it some you could come up with an angle that will work with a higher valve cover under it. You'll note the GM person that figured it out the first time did a little grinding himself - or herself - to clearance the high side of the valve cover as there is a little indent in the factory piece. Squirt it with a little semi-gloss black when you're done to match the factory brackets and nobody has to be wiser that you fabbed it yourself.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-23-2023, 03:17 PM | #6 |
hi guys, when i put my ac back on after header install, ( had to mod the lower bracket) I left the back bracket off. never any problems at all. BROWN 70
