Old 01-21-2023, 03:56 PM   #1
K10-Kansas
K10-Kansas's Avatar
Oil gauge mechanic electric
Hi. I am connecting the new wiring harness and putting in a new gauge cluster and am not sure if I have an oil pressure sending unit that connects to the wiring harness. I see the mechanic pressure line but do I also have an electric sensing unit? If so, I can't find it.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 01-21-2023, 04:02 PM   #2
K10-Kansas
K10-Kansas's Avatar
Re: Oil gauge mechanic electric
I think maybe I don't have electric anyway. Just mechanical. Is an electric sending unit just for idiot lights? I have a pressure line connected to the engine and pressure connection right here on the gauge cluster
Old 01-21-2023, 04:10 PM   #3
72SB
it would appear you have a mechanical gauge port on gauge cluster (one your finger is on) so run the OP line to that. Oil light would take a specific sender from whatever port you would install that in on the engine. The one you have above oil filter would work assuming you have a oil light in your cluster it would feed
72SB is offline   Reply With Quote
Old 01-21-2023, 04:12 PM   #4
truckster
truckster's Avatar
The 67-72 Chevy and GMC trucks only had either idiot lights or mechanical gauges.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-21-2023, 04:51 PM   #5
K10-Kansas
K10-Kansas's Avatar
Okay so it sounds like since I have an oil guage, there is no use for the oil wire on the new harness right? Thanks for the help on this.
Old 01-21-2023, 06:16 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
The oil pressure line on the back of your engine should enter the cab through a rubber bushing in the firewall. The interior end should have a small fitting on it that will screw into the oil gauge port on the back of the cluster, that you have your finger on. Screw it in carefully, it is easy to get it cross threaded. You will need a 5/16" open end wrench for the fitting. You will not need the wire in the new harness.
LockDoc
Leon
Old 01-21-2023, 06:40 PM   #7
K10-Kansas
K10-Kansas's Avatar
LockDoc
Perfect, thanks!
