Old 01-23-2023, 08:33 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Replacement TH350 Pan
The old steel OEM transmission pan has been straightened (again) and a new gasket installed, and it still weeps a bit of oil. I am ready to try an aluminum pan in hopes of a better seal. Looking for recommendations for a reasonably priced stock depth pan with a drain plug. So far I have looked at Summit's website and the number of pans they carry is impressive -- and confusing.
Also planning on a LubeLocker pan gasket. https://www.summitracing.com/search/...d=lub-llt-g350
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-23-2023, 11:27 PM   #2
RustyPile
RustyPile's Avatar
Re: Replacement TH350 Pan
No need to spend that much money for a pan gasket.. OEM "cork" gaskets work just fine.. The trick is to install the gasket "dry" and not over tighten the bolts. Tighten them a little at a time, evenly all around. Watching the gasket, tighten enough as the gasket just starts to crush.
Three years ago, I installed a Summit brand deep aluminum pan on the transmission in my truck.. The pan comes with all necessary hardware, bolts, gaskets, filters, etc.. Does it leak ---- not a drop.
https://www.summitracing.com/parts/sme-1000
RustyPile is offline   Reply With Quote
Old 01-24-2023, 12:17 AM   #3
Getter-Done
Getter-Done's Avatar
Years ago, a Guy I went to high school with,
And We worked at a Service station together.
He showed me the Trick.\
Use the Cork gasket and a thin coat of
Light brown chassis Grease and even torque on the pan bolts.
Hope this helps
84 Chevy K-20
Old 01-24-2023, 12:40 AM   #4
Accelo
Accelo's Avatar
I install all of the transmission pan gaskets dry. I mean clean and dry. Use some paint thinner or carb cleaner on both surfaces. Then install the gasket and torque to 13 foot pounds. You will not have an issue. I do not recommend the chrome pants under any condition. You will be much better off with the stock, steel pan or the aluminum like you mentioned.
Accelo is offline   Reply With Quote
Old 01-24-2023, 01:05 PM   #5
72SB
FWIW I bought a steel TH350 pan with drain plug and used a felPro gasket from auto part store. I just use a skim coat of transmission RTV between pan and gasket. Dry as a bone. YMMV
It is from Speedway but I bought from Amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I also got this magnet I put in the corner of pan
If you want a aluminum cast pan, I have used Hughes.
72SB is offline   Reply With Quote
Old 01-24-2023, 02:46 PM   #6
gmikkels
Hello,
Some times it is the shift shaft seal and not the pan gasket. May want to check it.
gmikkels is offline   Reply With Quote
