01-24-2023, 12:41 PM | #1 |
Engine stands
Are the big block and small block engine stands the same, except for the motor mounts (BBC = 3 bolt/ SBC = 4 bolt)? Just trying to verify. TIA
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-24-2023, 01:03 PM | #2 |
Re: Engine stands
Where did you find a small block that is 4 bolt? Bolt spacing is identical small and big. From the back of the block to the engine mount center has always been 16'' with the same 3 bolt pattern
01-24-2023, 02:05 PM | #3 |
Re: Engine stands
There are 4 bolt holes, but only 3 are used. Here is a picture of them mounted. Also have a picture of the stands which have multiple mounting holes and the 3 bolt big block mounts. The reason I am asking this question is that I'm doing a LT swap into my 84. I'm using the Dirty Dingo LT swap mounts and they sent me poly mount bushings for the 3 bolt mounts (BBC) when they were supposed to send me the 4 bolt mounts (SBC). Instead of sending them back, I am going to buy new 3 bolt Anchor mounts if they will fit. I've talked to Dirty Dingo, but the guy I talked to is more confused than I am. Here are some pictures.
01-24-2023, 09:27 PM | #4 |
Re: Engine stands
I thought you were talking about the block. My bad
01-25-2023, 09:07 AM | #5 |
Re: Engine stands
No worries. I think I have it figured out.
02-04-2023, 06:05 AM | #6 |
Re: Engine stands
On the small block 305/350 factory engines like long bed 1 piece drive shaft pic #3 is where it would be most times. Big block would be long bed 1 piece drive shaft #1. most time everyone does not put the 305/350 back in the right one then the drive shaft has a 1/2" more slop can be more prone to leaking on hill slop parking as time go on. ADD if your drive shaft is a little longer then then the #1 pic would not be as much of a problem.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 02-04-2023 at 06:13 AM. |
02-05-2023, 06:35 AM | #7 | |
Re: Engine stands
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
02-06-2023, 10:54 AM | #8 | |
Re: Engine stands
Thanks. I'm using the Dirty Dingo mounts, but they sent me the Big Block poly bushings and I want to use them instead of sending them back (as long as they will work). So the stands will work with any of the motor mounts is what I'm gathering...
