Old 01-25-2023, 04:23 PM   #1
72SB
Engine Temp Warning Light?
72 C10 with the gauge package option 253, amp, oil temp gauge.
The dash light for this "Engine Temp Warning" does not work when KOEO or while cranking the motor over. I have 2 senders. One on T stat housing base with a green/white stripe wire to it and a sender on the head (6 cyl) that has what appears to be a dark green (possibly black) wire to it and is a heavier gauge wire than the one to the other sender
Which one of these senders is associated with the Engine Temp Warning light?
I did pull that bulb and with bulb in its socket continuity test fail, Blub test good. Scraped brass insert that bulb slides in and now have continuity with bulb inserted in socket.
Temp Gauge works.
Both senders appear to be original but the wire on T stat base appears newer so may have been spliced or replaced at some point in its life. I have not un-taped that loom to see if that wire color, green with white stripe, is continues or is spliced into another color, original, wire.
or is the Engine Temp Warning light with the gauge option nonfunctional?
72SB is offline   Reply With Quote
Old 01-25-2023, 07:00 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Engine Temp Warning Light?
The engine temp light with the gauge option is not functional. It is not wired.
pjmoreland is offline   Reply With Quote
Old 01-25-2023, 11:28 PM   #3
ray_mcavoy
Yes, temp light is non functional / not wired with the full gauge cluster. I believe the only reason it's even present is because it's part of the gas gauge assembly ... which is the same as used in warning light clusters.
As for the engine having 2 temp sending units, I think one of them may be a temp switch for TCS (Transmission Controlled Spark) ... an early emissions system that GM used on many early 70's vehicles.
ray_mcavoy is offline   Reply With Quote
Old 01-26-2023, 11:26 AM   #4
72SB
It's a 3 OTT....
these pics show the sensor locations
One on head, DS and the other just under the T stat housing
Old 01-26-2023, 08:51 PM   #5
jaros44sr
jaros44sr's Avatar
Dang that's a Purdy engine bay
Wish mine looked like that
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-26-2023, 09:26 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
The 3 OTT trucks had TCS also. Mine did, but I don’t remember what color the wire was. I don’t see a TCS solenoid on your firewall by the heater box.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
