01-27-2023, 06:41 PM | #1 |
Stripping Cab
Looking for pictures from you guys/gals on how you stripped your cab down to metal.
Not looking to spend the money for media blasting, so I would like to know how much is reachable with a wire wheel, stripper, etc. Pictures always help, thanks in advance!
My 1970 C10 ChassisFab LWB to SWB Build Thread |
01-27-2023, 06:56 PM | #2 |
Re: Stripping Cab
Unfortunately no pictures, but we did strip about 5 coats of paint off a 64 C10 with solely paint stripper.
A bunch of razor scrapers with the plasic blades on them, and a weekend worth of work, 4 of us had it to bare metal. I don't think it was worth the results, the work, the caustic fumes or the burning (if you've ever been in a gas chamber like the military uses, it's slightly like that after several hours straight using stripper if you don't have proper ppe) It's also a lot of cleanup and general mess. All the panels need an indescribably thorough cleaning afterwards as well. YMMV, but I wouldn't walk that road again. I have to reserve my waning young and dumb moments for other truck work . |
01-27-2023, 07:08 PM | #3 | |
Re: Stripping Cab
01-27-2023, 07:22 PM | #4 |
Re: Stripping Cab
Never use paint stripper , it will get in the creases and come back to ruin any future paint work , 3m paint stripping discs work well . also 80 grit on a dual action sander . it's called body work not body easy .
https://www.ebay.com/itm/16584092107...Bk9SR5L3qdi-YQ
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-27-2023, 07:52 PM | #5 |
Re: Stripping Cab
I feel like there is no substitute for blasting on some areas. Grumpy is right, it's work. I used about every method possible.
If you can find a DA sander with 3/8 stroke, it seems to remove material much quicker than smaller stroke sanders. I used 7 inch version of the 3m stripping discs on my buffer, and some 2 inch versions on a pneumatic die grinder. I used stripper on the outside of the hood. You're going to need to use several methods to get it all. I tried to get as much as I could with the stripping discs or sanding, then finished up the grooves and hard to reach areas with blasting. |
01-27-2023, 09:47 PM | #6 |
Re: Stripping Cab
I use paint stripper on the big areas. Hoods, doors and fenders away from the seams as said above. Then on the rigid areas/tight areas that won't warp I have a 45 lb pressure sand blaster I use to get down to bare metal. After down to bare metal DA sanding and the epoxy primer
Pic of my 68 after stripping. |
01-27-2023, 09:57 PM | #7 |
Re: Stripping Cab
I used stripper on my cab for the '67. Stripper needs to be thoroughly washed away and neutralized. I stripped it about 12 years ago and primed it. No problems with any of the primer due to stripper. Do it right and you'll be fine
01-28-2023, 02:53 AM | #8 |
Re: Stripping Cab
No worries on the fumes from paint stripper anymore. It is banded from sales in this country and Canada. Even with training they were still killing people.
01-28-2023, 07:41 AM | #9 |
Re: Stripping Cab
I had to look that up. It's the ingredient methalene chloride that was used in paint stripper that has been banned (2019). I'll have to check the can I have to see if that has it. Probably does because it worked really well. Well, I didn't die or even get sick or dizzy. Just because someone gets training doesn't mean they obey all they learned. They only gave the one example of that and it was a 21 year old. I haven't been trained but I have common sense enough to know that stuff is a nasty unhealthy chemical I don't even want to touch my skin or breath. If it dissolves automotive paint and burns my skin I know it must be lethal. I use it outside and I never leaned above it. I follow the rule, if your nose is smelling it your lungs are feeling it. Works for me, except with odorless things. no worries now. That stuff is banned. I'll be extra careful when I finish that can off. The fumes are probably heavier than air, so the guy stripping the floor in his coffee shop was in a worse case scenario.
01-28-2023, 09:43 AM | #10 |
Re: Stripping Cab
4.5" strip discs compatible with a grinder bought in generic brands on ebay/amazon are the ticket. Those things fly through paint. Ill link what I buy thru black hawk. I think Grumpy turned me on to these things.
For rusted areas you may want to switch to a flap disc but these tear thru paint and even some filler. https://www.ebay.com/itm/121748111489
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
01-28-2023, 12:21 PM | #11 |
Re: Stripping Cab
For the areas where you can't get to easy with a stripping pad like under hood and edges of the fenders I used a Jobsmart siphon feed abrasive blaster it worked great , Low cost and used the fine grade of blasting abrasive ( coal slag) from Tractor supply They work with 80-100lbs of air pressure and uses 8cfm so it works but your not going to end up with warped panels that can happen at the commercial blasters that use 175 lbs of pressure . it worked so well for me I bought another one I wore out the tip on the first one (you can get new tips by calling customer service . Buy the blasting hood wear a face mask and NEVER USE PLAY SAND TO BLAST METAL !
https://www.tractorsupply.com/tsc/pr...ABEgKYvPD_BwE#
01-28-2023, 05:49 PM | #12 |
Re: Stripping Cab
Back when I used aircraft stripper I always did it with the shop door open. Safety glasses and a flip down face shield. Lots of plastic on the floor to catch stuff. Heavy duty rubber gloves.
When sand blasting a similar garb setup. I do wear dust mask to keep the sand out of my nose. |
01-28-2023, 06:42 PM | #13 |
Re: Stripping Cab
Stripped most of the 68 with the Eastwood SCT and the 3m disc that Grumpy posted and the ones that go on an angle grinder . Wire wheels for the tight spots but I came across a HF sandblaster my dad bought buried in the barn and did the nose with that . All finished off with a DA sander and 120 paper . Never liked paint stripper it’s good on wood trim but not for a car with nooks and crannies for it to lodge in . Truck is just about done
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-28-2023 at 06:53 PM. |
01-28-2023, 08:55 PM | #14 | ||
Re: Stripping Cab
01-28-2023, 09:02 PM | #15 |
Re: Stripping Cab
I'm really glad I bought it. They always have them for a good price at Carlisle
01-29-2023, 11:39 AM | #16 |
Re: Stripping Cab
I thought about trying the harbor freight version :
https://www.harborfreight.com/9-amp-...ool-58079.html |
01-29-2023, 01:25 PM | #17 | |
Re: Stripping Cab
01-30-2023, 12:03 PM | #18 | |
Re: Stripping Cab
01-30-2023, 12:40 PM | #19 | |
Re: Stripping Cab
Silicosis is a long-term lung disease caused by inhaling large amounts of crystalline silica dust, usually over many years. Silica is a substance naturally found in certain types of stone, rock, sand and clay. Working with these materials can create a very fine dust that can be easily inhaled.
01-30-2023, 12:50 PM | #20 |
Re: Stripping Cab
I used a combination of a hand grinder with a flapper disc, a random orbital sander, and hand sanding on my cab. I also used a wire wheel on my hand grinder for under the cab and on the interior.
I would each time pick a small area (like firewall) and proceed to focus on that until done, then move to the next area. Easy-peasy. Last edited by 68 C10 Driver; 01-31-2023 at 07:54 AM. |
01-30-2023, 05:25 PM | #21 |
Re: Stripping Cab
Just gotta ask, why do you want to strip it down to bare metal, especially in a damp climate? What is there has protected the metal for 50 plus years. I can understand sanding down to expose rust, repair dents, fix seam sealer, etc, but once those areas are done, some good 2k primer, block sanding and you will have a surface ready for another 50 plus years.
01-30-2023, 06:53 PM | #22 | |
Re: Stripping Cab
01-31-2023, 01:54 AM | #23 | |
Re: Stripping Cab
01-31-2023, 08:02 AM | #24 |
Re: Stripping Cab
Stripping to bare metal is known to be the best way to assure the best quality work, for a number of reasons. New paint is only as good as what it lays on.
I've owned my '72 K2500 for 22 years. I knew it had one repaint. It looked great and it wasn't a fresh job. Definitely had been painted a good while, so at least 30 years old now I'd say. In the last 5 or more years the hood and front fenders started getting fine splits showing up in the paint. Those started to lift and curl and flake off. I sanded down the bad spots and repainted. It kept on happening and as time goes by it is happening faster and over the entire part. The paint pops off to bare metal. I have no idea why. Maybe no primer, maybe mill scale on replacement parts. Maybe both, maybe defective paint mixing. I have no idea but for the first 15 years I had the truck I had no idea this was going to happen
01-31-2023, 03:42 PM | #25 | |
Re: Stripping Cab
All that said, I think I am going to just call one of the mobile blasters when I get my CJ project apart. It needs floor pan work and a few other places so I want to get it all done to see what I really have to work with. I'll throw some epoxy primer on it and then go to rust repair work.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
