Old 01-30-2023, 01:39 AM   #1
76JimmyBlue
Looking for brake master cylinder rebuild kit
I've got a 76 K25 camper special with 13" brakes nd I cannot find a rebuild kit for the master cylinder anywhere. Anyone know where to find one or is it unobtanium? I can just replace the whole thing but was wanting to learn how to rebuild one. Any help is greatly appreciated.
76JimmyBlue is offline   Reply With Quote
Old 02-04-2023, 05:19 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Looking for brake master cylinder rebuild kit
parts store that deal with "Standard" first try Rock auto web site if you can't find call them.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
