Old 01-30-2023, 10:07 AM   #1
liftlawssuck
liftlawssuck's Avatar
Slotted Wheel Lug Nuts
Looking for some lug nuts for slotted wheels for K10. The dia of the hole in the wheel is 7/8". I can't find lugs with that size dia. Short of getting some bushings made to reduce the size. Does anyone know of some that I could buy?
Thanks.
liftlawssuck is offline   Reply With Quote
Old 01-30-2023, 10:28 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Slotted Wheel Lug Nuts
Without knowing what wheel your trying to mount on what truck and no pictures your best bet is to take a lug off the truck and take the wheel to your local mag wheel dealer and they will have the lugs you need .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 01-30-2023, 04:08 PM   #3
Richard
Is the lugnut washer location for a keystone type washer? Like these- https://lugnutguys.com/collections/l...-offset-washer May be the reason for the larger hole. Only other thing is to maybe look for mag lugnuts that are used on a dually. Think the site that link is from has some with a .8" diameter shank.
Richard
Old 01-31-2023, 08:39 AM   #4
Why not get the correct bit for the lug nuts you can find and bore the holes?
I had a set of Turbines I got cheap when they went out of style. One wheel was designed to use the newer typical bevel back lug nuts and the rest used shank style. Having the tires rotated usually ended in some kind of lug nut issue due to ignorance of tire jockeys, but I was giving them an extra challenge. Finally I got fed up and bored the one wheel to accept the same mag style lug nuts. Life was good after that
