Old 01-06-2004, 02:33 AM   #1
leesnuts
Fleetside Rear Bumper Question
Does anyone know what rear bumper this is?
I found the pic on the net. I guess there is some difference between the 60-62 and the 63-66 rear fleetside bumpers. Can anyone expain the differences to me? I have a '58 fleetside I would like to install that bumper on, and I would like to know what all is involved. Thx, Lee
leesnuts is offline   Reply With Quote
Old 01-07-2004, 11:39 PM   #2
Yachtcare
Lee, Since the '60-'62 and '63-'66 trucks used a different frame the mounting points are what the difference is. You'll find the bolt holes are a couple of inches out of sync from one frame to the other. Also the earlier trucks used forged brackets, and on the later trucks they were stamped, but not certain if that would make any difference. Both front and rear bumpers are pulled off my '61 now, let me know if you need some measurements to compare with yours. My guess would be that you need a bumper from the earlier years to fit your '58 frame. Tony
1961 Chevy Apache 10 SWB fleet, 1970 GMC 1500 SWB fleet(getting 6.2L Detroit turbo Diesel), 1994 Chevy 3500 Crew Cab Dually 4X4 6.5L turbo Diesel. 1990 Chevy class "C" RV on G van chassis. Pics at www.picturetrail.com/yachtcare
Yachtcare is offline   Reply With Quote
Old 01-12-2004, 02:30 PM   #3
leesnuts
Does anyone know what the frame width measurments between the different years? Thanks Tony
-Lee
Old 01-13-2004, 01:10 AM   #4
Yachtcare
Lee, According to the assembly manual frame width 60-62 at rear frame end 41.72", 63-66 is 41.82". Not much difference. Putting the tape to my frame (61) I get 41.75". The bumper brackets are bolted to the frame rails and are set outward 14" for the outer mount hole and straight behind the frame rail for the inner. The mounting holes in the brackets are slotted .75" for adjustment R to L. The ends of the brackets are 9" behind the frame rail end at the top corner of the inner bracket. Center of mounting holes on each bracket is 14". I'm thinking the fit of the bumper is all determined by which brackets you use, provided your rear frame width is the same, or within .75 inches, of the later trucks. [IMG]Jan12232[/IMG]
Old 01-20-2004, 10:59 PM   #5
cochran63
cochran63's Avatar
isnt that truck a 58 or 59 gmc fleetside, not a 60-66?
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 02-04-2004, 03:21 PM   #6
leesnuts
This is a 58-59 fleetside, but the factory bumper looks gross. The 60-66 bumper looks much cleaner.
Old 02-18-2004, 09:52 PM   #7
Cdn.Fleetside59
Rear Bumper
The bumper in the picture looks identical to the one I removed from my '59 GMC. Have the brackets and the bumper ( needs rechroming ) available since have decided on something else for the rear of my truck. Let me know if interested . Bob
Cdn.Fleetside59 is offline   Reply With Quote
Old 02-20-2004, 06:00 PM   #8
kewlbear
60-66 rear bumpers are the same for the fleetside. The bumper
brackets are where they differ, 60-62 are different than 63-66. Hope this helps.
64 Chevy pickup
tilt,pb, ps discs up front
350/TH350, 72 rearend
auto meter gauges
93 GMC extended cab
trailmaster conversion
kewlbear is offline   Reply With Quote
Old 02-25-2004, 06:26 PM   #9
kewlbear
ooops, correction 60-62 and 63-66 bumpers are different,
looked at my parts book wrong. The 60-66 stepsides are
the same.
64 Chevy pickup
auto meter gauges
93 GMC extended cab
Old 03-03-2004, 03:17 PM   #10
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Unhappy 58-59 Hard to find
Lee,
I sell New Chrome Reproduction bumpers (with the drop down center - for the license plate viewing) for Chevy and GMC.
The years for Fleetside are shown as 1960-1962 and 1963-1966.
I also sell new reproduction Stepside rear bumpers in painted and chrome finish for 1955 (2nd series) through 1959. Sorry - no new reproduction rear bumpers listed for 1958-1959 Fleetsides.
PS: If it is a 58-59 rear bumper you are needing, then I would email Cdn.Fleetside59 as from the sounds of it he has what you are looking for?
my 2-cents worth...rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
