Old 01-06-2004, 04:24 AM   #1
magoo72
magoo72's Avatar
gears and gas milage/whatcha got?
what gear in the rear is the popular for gas milage ,what tranny is the favorite of my fellow truckers.
i run a 350/350turbo with 3.73 gears ,its allright for back and forth to work and local drivin and will snatch your head back into the rear window !!! but........... if i do have to get on the interstate it sounds like i am running @ Daytona. and the gas gauge falls rather quickly$$ i am building a new rear end w/3.08 gears,hoping not to sacrifice my boogidy,bogidy for better milage.
lemme know what yur running and how good is your milage/ btw i get bout 10 miles to the gal.
mr magoo
magoo72 is offline   Reply With Quote
Old 01-06-2004, 09:17 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
4.10s, 33" tires, 8-9MPG stock 350 running a little rich.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-06-2004, 09:20 AM   #3
mrein3
mrein3's Avatar
3.73 gears. 350/th350. 9.5 mpg most of the time towing my boat. 13 mpg was my best ever. That was not towing and I had a good tail wind.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-06-2004, 10:33 AM   #4
cdowns
cdowns's Avatar
4:10/200R4/275:60X15tires and i git 16.5mpg running 70-75 on the highway about 10-11 around town
Old 01-06-2004, 10:41 AM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
350/TH350/3.07. Usually around 12-13mpg on premium fuel...but my motor is built a little and i have a lead foot.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-06-2004, 11:06 AM   #6
JimKshortstep4x4
Talking
My son's truck is the one we use mostly and it has a 307/TH 350
with 3:07 gears. Gets 16 mpg.
Jim
Old 01-06-2004, 11:27 AM   #7
zigzag
327/3spd manul/4.56 gears on a 3/4 ton truck with some 8 ply mud grips.....maybe 8 MPG
zigzag is offline   Reply With Quote
Old 01-06-2004, 11:50 AM   #8
Paul72
Paul72's Avatar
K/20 - 350 w/ quadrapuke, 4sp, 3.73 open, 31" tires gets 10 mpg full, empty, warm, cold, north or south.
K/5 - 350 w/ 750 Holley, TH350, 3.08 open, 31" tires gets between 9-10.
Both 4X4's
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 01-06-2004, 12:02 PM   #9
BADA$$69
Walking accident
BADA$$69's Avatar
350/700R4/3.08 and I get about 12-13 MPG but I can't use the overdrive around town because in overdrive the engine only turns 1000rpm at 55mph. I haven't check the mileage on the highway yet. I need to get a 3.73.
Laurens, SC
69 C10 W/350 & 700R4
89 Mustang GT
BADA$$69 is offline   Reply With Quote
Old 01-06-2004, 12:59 PM   #10
8.1PWR
8.1PWR's Avatar
350 4bbl 4spd 4.10 rear. I get about 10mpg. Without an overdrive I'm turning some rpms on the freeway. I'm thinking of putting a 700R4 in the truck to get overdrive.
1970 Chev C20, 2wd, LB, 350 4BBL, muncie 4spd, 4:10 limited slip.
2002 Chev 2500HD 8.1L Allison, 4X4.
1996 Chev S10 Blazer, 4X4.
2006 Jeep LJ Rubicon
8.1PWR is offline   Reply With Quote
Old 01-06-2004, 01:04 PM   #11
miket
miket's Avatar
3.0's and a ZZ502=no gas mileage.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 01-06-2004, 01:25 PM   #12
Ackattack
Ackattack's Avatar
Working on it:
Was getting 10.4 on the highway, working on the carb and timing last trip I got 12.6. I'm hoping for 14, but my tires are too short I think. I'm running 295/50/15 now. Will be running 275/50/17s by summer hopefully. See sig for engine/drivetrain combo
Ackattack is offline   Reply With Quote
Old 01-06-2004, 02:03 PM   #13
1-PU70
1-PU70's Avatar
402 - 700R4 - 3:73posi - 31's
13.5mpg towing around 4500lbs.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 01-06-2004, 02:13 PM   #14
Willy Prost
Shortbed/ stepside/ 250 6cyl/ Tremec 3550 5-speed/ 3.73 gears/ 235-75-15 tires
15-17mpg around town
18-21mpg highway
Willy Prost is offline   Reply With Quote
Old 01-06-2004, 05:38 PM   #15
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
327/350/3.08 I have 255-70/R15 Around town I will get ~13. On the interstate running 75-80 (2800-3000rpm) I will, once again, get ~13.
If I do like 55 or so and keep my engine down at like 2300, then my mileage climbs ( but who wants to go that slow
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-07-2004, 09:21 PM   #16
jku72
68 C10 burb, 350, 4 speed, 3.07 rear, 31" tires, 18-19 mpg highway, 15-16 locally.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 01-07-2004, 09:54 PM   #17
breeh
Recovering 67-72 Addict
breeh's Avatar
K10, 427 with a 700R4, 4:10 axles with 33" rubber. 9 mpg in a headwind, with a tailwind, uphill, and downhill.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-07-2004, 10:49 PM   #18
1972C10
1972C10's Avatar
1972 C10 355 10.-1 3.73s 276/50r15 tires Gets about 2300 at 50 and 3300 at 70 its a miracle to bust 10mpg
1972C10 is offline   Reply With Quote
Old 01-07-2004, 11:13 PM   #19
1974StepSide
Play it Loud...
1974StepSide's Avatar
350 cid, Turbo 400, 3.08's in the rear, lead foot = about 11-12 mpg...
Big Moe
1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint.
1952 Chevy Pickup waiting to be brought back home!
1974StepSide is offline   Reply With Quote
Old 01-07-2004, 11:32 PM   #20
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
with a 350/TH350 3.73 gears and 26 inch tall tires i get around 8-9 taking it easy. i don't want to know what it gets when i put my foot into it. but who cares about gas mileage when you got power!
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 01-08-2004, 12:09 AM   #21
jewels.
jewels.'s Avatar
350
3 speed stock tranny
3.73 gears
255/60/R15 tires
2bbl carb
12-13 mpg in town
18-19 mpg highway
i think that might be outperforming some of the new SUVs out there!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 01-08-2004, 01:18 AM   #22
jorgensensc
jorgensensc's Avatar
1972 step 383/350/3.08 (I think)
10 mpg city, 13 highway running 75-80 at 4000RPMs
and yes jewels you are, Our 2002 Dodge Durango with 5.9 and auto only got 12-13 highway. My wifes new 2003 audi a4 quattro with 3.0 only gets about 18-21mpg, but I have a lead foot!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-08-2004, 01:37 AM   #23
1969 GMC
1969 GMC's Avatar
I still have a bunch of question marks. I don't drive crazy like alot of people here do, I only go to about 2500 rpm and thats it. According to the p/o, the original 4.10's were swapped for 3.73's.
'73 stock 350, SM465, 3/4 ton 4x4...and I swear that I can get close to 18 on long highway trips, If I keep my foot out of it (which I usually do). But, since I never go on long highway trips in my truck, I never get that good of gas mileage. I'd guess 14 or 14 on the highway to and from work and school, and around 10 in town.
Here's how much of a grandpa driver I am- I consider opening the Qjet's secondaries a special occasion, that rarely happens.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-08-2004, 02:08 AM   #24
rn2fine
rn2fine's Avatar
Mileage
1972 Suburban C10 2wd, late model 350, edelbrock carb, vortec heads, headers, TH700, 3.07 gears, mostly highway with some city driving, 14.7 mpg
rn2fine is offline   Reply With Quote
Old 01-08-2004, 02:12 AM   #25
500HP/SB
please don't break
500HP/SB's Avatar
'70 k10 350/sm465 35inch tires dual quads= i dont want to know
probly 5-10mpg
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
