02-01-2023, 09:11 PM | #1 |
A/C heater help
I am upgrading the A/C heater combo in my 54. The old system was a Air-Tique vacuum operated valve system that did not work. I have looked at the Old Air and the Vintage Air stuff. I do not want to cut another big hole in my firewall. Looking for some advice as to what is the best system for me to fit my truck. I like the bulkhead fitting, and electric valves. I have included pictures of the old system
02-01-2023, 09:16 PM | #2 | |
Re: A/C heater help
In fact, I have a 1959 261 inline 6 engine and Vintage air had a bracket that fit on the engine to support both the compressor and the alternator.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
02-02-2023, 11:23 AM | #3 |
Re: A/C heater help
Do you have any pictures?
02-02-2023, 11:46 AM | #4 |
Re: A/C heater help
I purchased a VA direct fit unit and modified how it was installed so you don't see much. I contained the valve inside the cab close to the unit. I used a bulk head fitting on the passenger side cowl and ran the hoses down under the frame and up form the bottom. This worked good for my LS set up.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-02-2023, 01:43 PM | #5 |
Junior Member
Re: A/C heater help
Brilliant!!!
