Old 02-04-2023, 07:46 AM   #1
Oil pressure guage is pegged all the way to the right, any ideas why ?
Possibly a dead short? The pressure switch is a new (A/C Delco) one, it’s stays pegged and does not move at all, key on or key off, pulled the single wire off…no movement.
Any help would be much appreciated.
1987 SILVERADO, factory original, new 5.7 TBI truck
Old 02-04-2023, 10:27 AM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Oil pressure guage is pegged all the way to the right, any ideas why ?
Sounds like its grounding somewhere. What did it do before the new sensor?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-04-2023, 11:01 AM   #3
Before pulling engine and overhaul it worked fine….
Old 02-04-2023, 11:04 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
Sounds like you installed a switch instead of a sender. The switch is for the dummy light models. If you have a gauge, you need a sender.
Old 02-04-2023, 12:40 PM   #5
Thanks !
Interesting, I will check it out further. I have bought both the switch (installed) and recently bought a sender. The switch screws right into the fitting on the block, the sender is a smaller diameter and will take some kind of reducer….
Problem is I’ve been working on this truck for a couple of years, sporadicly, so I sometimes forget where I left off
Old 02-04-2023, 01:20 PM   #6
72c20customcamper
What does it do when you ground the wire ? Think I had a fuel gauge workings when I responded . Doesn’t the oil sender peg when it’s unhooked.?
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
