Old 02-05-2023, 06:59 PM   #1
mehoff400
heater fan doesn't work on high setting
recently replaced the fan speed switch and it still seems my fan doesn't work in the high position any thoughts on what to check?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 02-05-2023, 11:38 PM   #2
bigdaddy4x4
bigdaddy4x4's Avatar
Re: heater fan doesn't work on high setting
the blower motor relay controls the high side of the blower motor its rite by the blower motor check it out
bigdaddy4x4 is offline   Reply With Quote
Old 02-06-2023, 11:25 AM   #3
temp190
Junior Member
Had issue with high on mine and only thing i found was ground near blower motor bad, repaired and it started working again.
temp190 is offline   Reply With Quote
Old 02-06-2023, 12:40 PM   #4
Dead Parrot
Make sure any fuses or links on the full speed wire from the junction block are still good.
Dead Parrot is offline   Reply With Quote
Old 02-06-2023, 11:59 PM   #5
mehoff400
Figured it out. I installed a painless kit and painless heater a/c harness. I didn't realize the painless kit uses a ground and its own relay for the heater and apparently it only uses the relay on high and didn't have the ground connected. Once I hooked it up correctly everything works as it should
My truck
