Old 02-06-2023, 11:59 PM   #1
lugnut
lugnut's Avatar
Painted tailgate letters
Can someone post a pic of original white painted letters on a tailgate? I'm looking to see if the paint stayed in the recessed area or if it came out to the outer edge. Fleetside gate please.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
Old 02-07-2023, 12:54 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Painted tailgate letters
This should help .
https://www.youtube.com/watch?v=W7J3x_OwQUQ
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-07-2023, 03:46 AM   #3
Richard
Think there are few threads about the lettering on the site this is one of the first that came up with a search https://www.67-72chevytrucks.com/vbo...d.php?t=762735
Richard
Old 02-07-2023, 10:36 AM   #4
72c20customcamper
72c20customcamper's Avatar
My oem tailgate on 72
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-07-2023, 03:35 PM   #5
wrangler94
Ok, on this topic. Were all the tailgates painted with white letters? Or was that an option? I'm 97% sure (ok 197% sure) that my 1970 was repainted before, at least on the inside. But my tailgate letters are not white. Should they be?
wrangler94 is offline   Reply With Quote
Old 02-07-2023, 07:24 PM   #6
72c20customcamper
Depends . My original gate was gold with white that had been repainted but the letters should have been the gold . This is when I picked up the take off gate
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-07-2023, 07:29 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I had the same question last spring and here is the link and don't think we got a definitive answer other than maybe a plant to plant anomaly.
http://67-72chevytrucks.com/vboard/s...d.php?t=832500
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-10-2023, 02:28 PM   #8
mrein3
mrein3's Avatar
I had a better tailgate I bought that I wanted to paint when I painted my truck. The one I got on the truck was bowed and lead a rough life.
I was wondering the same thing so before I scratched off all the original paint, I took a close-up picture of the letter area.
You can clearly see not a lot of care was taken when the masked off the white as the lines aren't straight and there is color overspray on the white.
And to directly answer your question, in my example they attempted to keep it in the recessed area. I would guess there may have been variation between plants.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-11-2023, 09:19 AM   #9
The paint was intended to stay on the flat. I believe this type of accent painting was done with stencils, going by the misted edges you often will see
Old 02-11-2023, 11:03 AM   #10
72c20customcamper
MAR-K makes or did make the stencil this is basically what GM would have used
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-11-2023, 07:20 PM   #11
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
White or otherwise should be the same, I think. This isn't factory but boy did the painter do a nice job. I can take a close up if needed.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-11-2023, 10:11 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm calling most "plant anomalies" a drug issue. I'll allow that some people are just bored, and don't care, to be another answer. My first day on the assembly line (I'm a day person, and I got picked up for second shift) I mentioned that I was tired, and was offered speed (not by management). I declined. Assembly line work is pretty boring, needless to say, and drugs are a common problem.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 02-12-2023, 01:37 PM   #13
71CHEVYSHORTBED402
Such as the rivets they missed on my C10, one at a leaf spring hanger and two at the transmission cross. They also drilled the wrong for a Deluxe badge.
Tony
