Old 02-08-2023, 11:33 PM   #1
Arne
Arne's Avatar
How to identify front drop springs?
Here's the deal. I bought the truck as a stalled project, and it was already lowered. I have no idea how much it was dropped. Both front and rear drops were all coils.
I'm thinking I might want to bring the front up an inch, but don't know what springs are in it now. I have between セ to 1" of travel before it hits the bump stops. Tires are 275/60-15 at around 27" tall, and I have about 27ス" fender height.
The springs are black, but I haven't found any markings on them. The front sway bar and panhard rod are labeled POL, but the shocks look like CPP. So the springs could be either brand.
Can anyone help me figure out what I have in there now?
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 02-09-2023, 08:15 AM   #2
sambrutay
sambrutay's Avatar
Re: How to identify front drop springs?
most spring only drops are 3" front and 5" rear.
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline   Reply With Quote
Old 02-09-2023, 01:35 PM   #3
theastronaut
theastronaut's Avatar
Best bet for raising it exactly 1" is to use a spring spacer; 1/2" thick will gain 1" at the spindle/wheel. You could order a new drop spring and it not be the exact amount of drop it's advertised to be, every truck is different.
Or if you like the height and just want more travel before bottoming out, cut the bump stop brackets off the lower control arms. The ball joints have plenty of travel left, more travel than the crossmember has ground clearance.
theastronaut is offline   Reply With Quote
Old 02-09-2023, 03:08 PM   #4
Arne
Arne's Avatar
While I don't need exactly 1", the spring spacers sound like a good option. I just feel that more travel would be good, and it has a bit more rake than I'd prefer.
Got any favorite sources for spacers?
- Arne
覧覧覧覧覧覧
Old 02-09-2023, 03:18 PM   #5
LVPhotos
LVPhotos's Avatar
Remove stock bump stops.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-09-2023, 04:41 PM   #6
forestb
forestb's Avatar
Here is mine wit a 4.5 in drop up front and 5 in the rear with the same size tires. Hopefully it will give you some kind of reference.
forestb is offline   Reply With Quote
Old 02-09-2023, 07:38 PM   #7
Arne
Arne's Avatar
That is helpful, thanks. Looks like mine might be 3" drop on both front and rear.
- Arne
覧覧覧覧覧覧
Old 02-09-2023, 11:34 PM   #8
AcampoDave
AcampoDave's Avatar
Looks like a 3 inch. Here's a 2 front with a 4 in back.
AcampoDave is offline   Reply With Quote
Old 02-10-2023, 12:10 AM   #9
Arne
Arne's Avatar
I think you are right. Now all I need is to find someone who wants to trade a pair of 2" springs for a pair of 3".
- Arne
覧覧覧覧覧覧
Old 04-19-2023, 04:58 PM   #10
Arne
Arne's Avatar
Update - I haven't found any spacers that will both fit, and raise it more than シ". So I'm back to looking at the springs. I'm fairly sure mine are from CPP, and probably a 3" drop. CPP support says they should have a part number on them if they are theirs. I can't see a number anywhere while they are in the truck, so later this weekend I'm going to drop one out for inspection. If I can ID them as 3", I'll buy a pair of 2" drop to install instead. I guess I'll have a surplus pair of 3" drop springs at that point.
- Arne
覧覧覧覧覧覧
Old 04-21-2023, 02:46 PM   #11
Arne
Arne's Avatar
And of course, no numbers are visible on the springs I removed. So I started looking up specs.
You can determine the drop by the free length of the spring. Here's a summary of drops to free length, assuming that the springs in question have a spring rate close to stock (1000-1100 lbs/in) and the wire is 0.75-0.82 thick. (All the spring makers that I found specs for met all these criteria.)
Code:
Stock height ---- 12.5"
1" drop --------- 12.0"
2" drop --------- 11.5"
3" drop --------- 11.0"
4" drop --------- 10.5"
Mine are 11.0", so the thoughts from above that they looked to be 3" were correct. I've got a pair of 2" on the way, and have posted the 3" in the classifieds.
- Arne
覧覧覧覧覧覧
