Old 02-09-2023, 12:43 PM   #1
Tom
driving is in my blood
Tom's Avatar
Shift lock issue 98 sierra
I have an issue lately where sometimes it won't release the shift lock for the auto shifter. Most times, I have to push the pedal to the floor, sometimes I have to push it several times before it releases. I know the brake light switch is working correctly, the brake lights come on the moment I touch the brake pedal. What else could be causing it?
Old 02-09-2023, 02:28 PM   #2
sntrym95
sntrym95's Avatar
Re: Shift lock issue 98 sierra
The lock solenoid is up under the dash attached to the column, right side of the column IIRC. Try unplugging it to get the solenoid to disengage.
When the park/neutral position switch is in park and the brake switch is closed (foot off the brake) the circuit to the solenoid is completed to lock out the shifter.
Mike
sntrym95 is offline   Reply With Quote
Old 02-09-2023, 02:32 PM   #3
sntrym95
sntrym95's Avatar
You can pop it off of the linkage too if you don't want to bother with it.
Mike
Old 02-09-2023, 04:59 PM   #4
Just call me Sean
Just call me Sean's Avatar
That's what someone did with mine, so I left it.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 02-10-2023, 01:58 PM   #5
Tom
Tom's Avatar
Excellent thank you!
