Old 01-06-2004, 01:05 PM   #1
smokekiki
Mike
smokekiki's Avatar
power steering.
I am having problems with my steering.3/4t 4x4 sub.It has a new pump and belt.When going down the road everything is fine.When parking it can be a bear to turn into a space.There are no leaks and the truck handles good.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-06-2004, 04:12 PM   #2
cdowns
cdowns's Avatar
probably the size of your tires that box and pump weren't designed for lift and big tires. check with a company called AGR i saw a write up in a mag azine once and i think they have a bolt in upgrade fot these trucks about $500-$700 range
Old 01-06-2004, 04:33 PM   #3
smokekiki
Mike
smokekiki's Avatar
I am running 285/16's.About 32"x11".
Old 01-06-2004, 05:24 PM   #4
6869704X4
Does it work better if you increase RPM? Kinda tricky while trying to park but give it a shot in an empty lot or something.
I have played with the valve in the back of the pump. Changed the piston and stuff. Mine is better now. The reason I had to do this is my old style keyway pully got trashed. I had to switch to the press-on style. The new pump pulley was bigger, and therefore spun slower. I think that is my biggest problem.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 01-06-2004, 06:03 PM   #5
Tanker350
I'm running 275/15, and I have no problems with my power steering. I cant recall off hand, but can't you adjust it like you do the manuals? Is it hard to turn when you do it both directions? Maybe try looking into that.......My .02 cents
Tanker350 is offline   Reply With Quote
