Old 02-12-2023, 03:24 AM   #1
Bushman66
Gauges in the Heater Switch Panel?
Anyone mount a couple of gauges in the panel where the heater switch is? I've removed the Thrift heater system completely, I'm planning to add a Vintage Air under dash AC/Heater system as soon as the wiring is finished.
This panel looks like the perfect place to mount a Oil Pressure and Water Temperature gauge.
Anyone have any pics of an install similar to this?
Bushman66 is offline   Reply With Quote
Old 02-12-2023, 07:53 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Gauges in the Heater Switch Panel?
I know I've seen em mounted in the heater control panel, just can't find a pic right now.
Old 02-12-2023, 09:58 AM   #3
60short
60short's Avatar
Skinny G did air gauges hidden in the ashtray
https://67-72chevytrucks.com/vboard/...postcount=1105
https://67-72chevytrucks.com/vboard/...d.php?t=756182
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 02-12-2023, 01:21 PM   #4
SkinnyG
SkinnyG's Avatar
Cool! I was about to post that...
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 02-12-2023, 02:25 PM   #5
pdxhall
pdxhall's Avatar
You may want to decide on your AC controls are going to go before adding gauges to that spot.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 02-12-2023, 05:36 PM   #6
Bushman66
I'm pretty sure I'm going to do the Mark V underdash unit from Vintage Air, all the controls should be directly on that unit, but I will confirm. Going for the old school look...
Old 02-12-2023, 06:38 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
That's cool! I installed my nitrous arm and purge buttons in my ashtray.
http://youtu.be/vldlvb3fyik
Originally Posted by 60short View Post
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-13-2023, 09:31 PM   #8
AcampoDave
AcampoDave's Avatar
Here's a guage and temp light with VA controls in the radio delete
AcampoDave is offline   Reply With Quote
Old 02-14-2023, 01:04 PM   #9
pdxhall
pdxhall's Avatar
Great choice on AC. That's the unit I am considering. In that case I think the gauges in the heater control spot looks great. I haven't decided what to put there.
Sanity'66
Old 02-15-2023, 07:05 PM   #10
Bushman66
That looks great!!
Old 02-15-2023, 09:04 PM   #11
AcampoDave
AcampoDave's Avatar
Thanks, I bought the red LED dummy light from O'Reilly's and the sender for it was a generic 135 degree brass one on Amazon. The sender will sometimes trigger the light when I restart the motor on triple digit days after a brief hot shutdown.
