Old 01-06-2004, 02:06 PM   #1
gotmud
gotmud's Avatar
wire looms
Need help with plug wire looms.
Got a 68 307 with the stock valve covers and exhaust manifolds. I bought the accel wire looms
(http://www.jegs.com/cgi-bin/ncommerc...22&prmenbr=361) but they wont fit because the the manifolds rise up from the exhaust ports.
Any ideas or options?
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-06-2004, 02:30 PM   #2
Randy70C-10
Randy70C-10's Avatar
Those are designed for use with headers. I'm assuming that you have ramhorns?
Randy70C-10 is offline   Reply With Quote
Old 01-06-2004, 03:07 PM   #3
gotmud
gotmud's Avatar
Never heard them call ram horns but now that you say it thats exactly what they look like! Maybe one day I can afford the headers and will mount the ram horns on the wall in the garage.
Glenn
Glenn
Cumming, Ga
Old 01-06-2004, 03:24 PM   #4
Blue Beard
Blue Beard's Avatar
I used new wires with the straight boots...
They went out far enought for clearance and plenty of wire length.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-06-2004, 10:08 PM   #5
gotmud
gotmud's Avatar
How do I organize them though so they dont look like a bird nest as they go over the valve covers? My neighbor says thats what coat hangers were made for.....
Glenn
Cumming, Ga
Old 01-06-2004, 10:26 PM   #6
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
do one wire at a time and work from the back of the towards the front.
67Fleetsidedream is offline   Reply With Quote
Old 01-07-2004, 11:52 AM   #7
fatfords
fatfords's Avatar
You might try getting some steel pipe and cutting 4 spacers to use between the valve cover and the loom (2 per side). You would need longer bolts, but you might be able to make it work.
Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 01-07-2004, 04:58 PM   #8
Davy
Davy's Avatar
see this post about half way down by racedvl. he used wire ties, looks pretty good and cheap.
http://67-72chevytrucks.com/vboard/s...s&pagenumber=3
Davy
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 01-07-2004, 05:02 PM   #9
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Davy
Hey, that is a pretty slick way to do it! You can even get pretty colored zip ties, too. I like it!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 01-07-2004, 05:49 PM   #10
Blue Beard
Blue Beard's Avatar
That is a good idea with wire ties.....
Think I would put the cut section on the bottom side to keep form getting cut on and for looks........
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 01-07-2004, 06:17 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
If you have an HEI and rams horns, get plug wires for a 75 vette application. They are long enough to route properly behind the block, along the frame rail, and up under the ramhorn manifold.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-07-2004, 07:09 PM   #12
J.Lance
Too many is never enough!
wire looms
I had bought some wire looms that were intended to bolt onto the valve cover bolts. Ended up buying some spacers and longer bolts to clear the manifolds and still looks really good. That being said, I'm going to convert it back to stock routing with the vette HEI wires mentioned above. Nothing looks as clean as the stock routing and works better to protect the wires. Wouldn't want to think about downgrading my ram horns to headers either but that's just me.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
