Old 02-14-2023, 10:48 AM   #1
72SB
Threshold Plate?
For those who have these, are they glued or screwed on?
Not seeing holes in the LMC plates so assume glued (self stick?)
https://www.lmctruck.com/1967-72-che...old-plate-sets
I would not mind if there were rubber available although the LMC SS would go with the SS sill plates currently on the truck. There are some nicks in the paint on threshold so was considering threshold covers as it's a high traffic spot prone to nicks and paint chips.
I do see 38-2434 in the LMC link for a rubber one although it's for Suburban. Isn't threshold same length as C10...or?...maybe cut them down??
https://www.lmctruck.com/1967-72-che...ill-plate-sets
72SB is offline   Reply With Quote
Old 02-14-2023, 12:29 PM   #2
OregonNed
OregonNed's Avatar
Re: Threshold Plate?
Curious too of how they mount
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 02-14-2023, 02:23 PM   #3
29od1
3M two sided tape
29od1 is offline   Reply With Quote
Old 02-14-2023, 02:32 PM   #4
CG
BlahBlahBlah
Burb would be the same as truck
Old 02-14-2023, 05:05 PM   #5
72SB
ordered ...SS Threshold Plates from LMC
I suspected self-stick, thanks for the reply 29od1
Old 02-15-2023, 09:25 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have some aluminum diamond tread thresh hold plates on my '68 C/10 Stepside. I drilled 4 holes in each and screwed them down.
I bought them at Checker Auto years ago. I have not seen this type for sale for a while.
Old 02-16-2023, 04:39 AM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I boughta set of these from Wes at Classic Hearbeat and they have the holes and he also sells the same set without the bowtie.
https://www.classicheartbeat.com/pro...ated-w-bowtie/
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 02-16-2023, 07:34 AM   #8
These threshold plates the OP is talking about are accessories, similar to a tailgate protector. They sit on top of the rocker panel and bend over the outer edge. Usually stainless, but there used to be ones made in diamond plate aluminum
Old 02-20-2023, 07:39 PM   #9
72SB
Got the LMC Threshold Cover installed. Self-stick, stainless steel. Fit is excellent. They tuck under the door opening rubber and the rolled edge fits snug against threshold.
Painted threshold was getting nicks so these should resolve that and easily wipe clean. Fortunately, being SS they do not exceed the allowable chrome limit I have.
Old 02-20-2023, 09:40 PM   #10
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
300 series stainless steel (the type that doesn't rust) is at least 18% Chromium. I like those, though, and may get a set for my truck.
~Steven
Simi Valley, CA
Old 02-23-2023, 11:46 PM   #11
OregonNed
OregonNed's Avatar
I'm glad you posted a pic! Looks great! Guessing this will be a near-future upgrade for me,
