02-15-2023, 06:57 PM | #1 |
Window Regulator Issues just an FYI
I ordered two new window regulators recently.
I installed them on my doors. Each one will not take an original splined window crank. Close but no luck. If you try to force or bump it on it just kills the splines in the handle. The ones I got were from CJ, perhaps LMC has better quality. If you have recently done this let me know where you found ones that worked well. |
02-15-2023, 09:04 PM | #2 |
Re: Window Regulator Issues just an FYI
I bought one recently that is made by Dorman. It's a well-made product and fits and operates as it should.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
02-15-2023, 09:06 PM | #3 | |
I found it, Dorman 752-136 & Dorman 752-137 Last edited by Auctioneerhere; 02-15-2023 at 09:49 PM. |
02-15-2023, 09:11 PM | #4 |
I'll have to look for it. Right now I can't remember who I bought it from. That's what getting old does to you.
02-16-2023, 03:40 PM | #5 |
Moderator
I bought mine from The Truck Shop in Orange, CA and havnt had an issue.
02-16-2023, 04:00 PM | #6 |
Oops. I posted to the wrong thread.
02-25-2023, 11:15 AM | #7 |
I have the same problem with one window regulator. Looking forward to seeing if a solution is found.
1964 C-10 short bed 406 small block 700R4, 4:11 gears 20" wheels |
02-25-2023, 12:18 PM | #8 | |
02-28-2023, 12:38 PM | #9 |
After several OEM window cranks, I have come to realize if you order new regulators, just get new crank handles.
My OEM handles did not work with the CJ Pony parts regulators or the LMC regulators. I found the LMC regulator to be of much higher quality than the CJ brand. My "Next Day" Dorman regulators turned into next week or whenever we feel like delivering them, regulators. |
02-28-2023, 05:57 PM | #10 |
05-16-2023, 06:55 PM | #11 |
Me too. I went through 3 different companies and still no luck. I'll try the Dorman number. The sad part is you can't even talk to someone that knows anything, just someone answering phone.
06-05-2023, 08:52 PM | #12 |
A quick clarification - the Dorman 752-136 & 752-137 are for '60-63.
For '64-66 you need 752-138 & 752-139 instead. |
06-05-2023, 09:27 PM | #13 |
Just for the record, I ordered from "https://www.classicparts.com/" for my 1960, and it fit my aftermarket cranks just fine, and hasn't slipped yet... not sure who made it however
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
