Old 02-17-2023, 12:40 AM   #1
rhamer88
Turn Signal Lever Hard to Move
Evening everyone. Got an issue here that I can't seem to figure out.
I've got a 1984 C10. A few months back I noticed that my turn signal was getting harder and harder to move to the left and right to activate the turn signals. I replaced the turn signal switch in the column and it worked fine for a few weeks, and then the same thing started to happen again. I took everything apart and loosed up all the screws and then tightened them back down again. Same thing; worked great for awhile and then started happening again. This last time, I took it apart and used some dielectric grease on the moving parts thinking that maybe it just needed some lubrication. It's worked great for the past few weeks, but now it's doing the same thing again.
As a side note, I also replaced the wiper control switch at the same time (I'm blanking on the correct term for the part, but where the turn signal stock attaches inside the column).
Does anyone have any idea what's causing this and what I can do to fix it? Any insight would be greatly appreciated.
rhamer88 is offline   Reply With Quote
Old 02-17-2023, 08:34 AM   #2
chrismoore701
chrismoore701's Avatar
Re: Turn Signal Lever Hard to Move
Do you have the correct mounting bolts? I think there is a shoulder on them so should stay easy to move
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-19-2023, 12:52 AM   #3
rhamer88
Unless someone monkey’d around in there before I owned it, they should be correct. But we all know about “previous owner syndrome”, so I’ll pull them out and check if they’re shouldered or not.
Old 02-20-2023, 10:44 AM   #4
Pontiac1976
Pontiac1976's Avatar
Maybe the springs are jamming up in the turn activator mech. cam or there a crack in the activator mech. cam somewhere and it's jamming. The only other thing might be short in the column, it may be getting good ground connection to the body.
I'm not how you removed turn signal leaver I will give you this link: You may what to check the switch make sure it ok to rule it out.
I hope this may help you.
https://bowtieguy.proboards.com/thre...-cruise-switch
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-20-2023, 12:23 PM   #5
rwjtexas
Junior Member
One thing to consider is there are two different cancelling cams .. one for tilt and one for non tilt steering .. one is green and one is white … unless you changed it out it could be the incorrect one .. just something else to check when you are looking in the column
rwjtexas is offline   Reply With Quote
