Old 01-06-2004, 03:31 PM   #1
danho
Pesemistic Optimist
danho's Avatar
Hoses
Anyone have the part number for the upper radiator hose. I'm looking for the all rubber one to replace the metal one on my 72.
Also, is there any reason I can't have a hydraulic hose made for my PS pump? One is hydraulic with the pressed on fittings, and the other one has hose clamps on the ends and it leaks. Just checking.
Thanks, Dan.
danho is offline   Reply With Quote
Old 01-06-2004, 03:46 PM   #2
cdowns
cdowns's Avatar
that's the way they came from the factory the hose with the clamps is the return (low pressure) hose
i don't see why you couldn't get a hose made up to do away with the clamps
Old 01-06-2004, 03:49 PM   #3
cdowns
cdowns's Avatar
upper rad hose part#20686 from carquest (gates)
Old 01-07-2004, 10:23 AM   #4
danho
Pesemistic Optimist
danho's Avatar
Thanks for the info, Dan.
Old 01-07-2004, 10:52 AM   #5
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
I think most of us use a 73?? chevy upper radiator hose. Its all rubber. I dont know the part number though.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-07-2004, 01:42 PM   #6
tomsC10R
tomsC10R's Avatar
danho,
I just talked to a gentleman that runs an Earl's retail store. He said that he has welded on an AN fitting (or I suppose what ever kind of fitting you wanted) onto the end of the low pressure "stub" (whatever it's called ) for customers in the past. Just an idea. I might have it done with mine. Good luck.
Tom
1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes.
tomsC10R is offline   Reply With Quote
