02-17-2023, 04:49 PM | #1 |
belt routing
I am building a 350 and would like an opinion on belt routing. What do you gus think of this. The AC is a vintage air system
The alternator is one (1) groove, lined up with the outside groove of the crank. All other pulleys are two (2) groove including the crank pulley Will this work? Alt. to WP to Crank, outside groove PS to crank inside groove AC to wp inside groove Thanks guys
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
02-17-2023, 06:47 PM | #2 | |
Re: belt routing
The a/c needs to wrap the crank also. The crank is what drives everything.
02-17-2023, 07:36 PM | #3 |
Re: belt routing
The OEM version has the AC belt just catch the PS pump + the crank. The PS pump main belt also wraps the water pump. The Alt also catches the water pump. But the OEM version has a 3 belt crank pulley.
The big issue I see with your idea is you are asking the Alt belt to drive the Alt + water pump + the AC indirectly via the red belt. And you don't have much touch area on the water pump drive belt. Probably get a lot of slippage. My suggestion is either get a 3 grove crank pulley and use the OEM routing or swap out to a serpentine setup. |
02-20-2023, 08:27 AM | #4 |
Re: belt routing
thanks, looking for a 3 groove crank pulley
