Old 02-17-2023, 05:38 PM   #1
70C10Ginger
70C10Ginger's Avatar
Edited by Moderator
Attachment 2258828
I got into a fender bender after 40,000 miles. I’ve been able to replace everything locally, Utah area.
(Since it matters, uploaded pic three times and it was sideways every time)
Thanks for everything guys!
70C10Ginger is offline   Reply With Quote
Old 02-18-2023, 12:24 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Edited by Moderator
Sorry for your bad luck....
Unfortunately I had to edit your thread. You can't post a want to buy unless you are a Premium member. If you see something for sale on the parts board you can buy it though.
On the other hand, I have a turn signal and possibly one headlight bezel that I will send you for the cost of postage. I will PM you.
LockDoc, Moderator
Leon
Old 03-04-2023, 06:32 PM   #3
LockDoc
LockDoc's Avatar
Here are pictures of the parts. I have never owned a GMC so I don't know which light is the drivers side. The headlight bezel has surface rust but you can see where I cleaned it up in the corner, with 0000 steel wool. I think it would clean up pretty good. Here again I don't know if this is right or left or if they will interchange. If you are not sure, maybe someone that knows will chime in.
Let me know what you think. These are the only GMC parts I have.
LockDoc
Leon
