02-17-2023, 06:17 PM | #1 |
1963 GMC 2wd rear end gear
Hello all, I have a 63 GMC with a Dana 44 rear and I was wondering if anyone would now the stock gear ratio? My gear tag is not on it Thanks in advance
02-17-2023, 11:09 PM | #2 |
Re: 1963 GMC 2wd rear end gear
3.07 or 3.54 for 2WD, 3.54 for 4WD were the 'factory' choices.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
02-22-2023, 11:16 AM | #3 |
With the transmission in neutral, rotate the rear driveshaft by hand. Count the number of driveshaft revolutions required for one revolution of the tire.
If the driveshaft turns approximately 3-1/2 times, you have a 3.54 ratio, etc. It is helpful to use a grease pencil or chalk to make a reference point on both the tire and driveshaft while performing this test. Number of Turns Approx. Gear Ratio 3 3.05 : 1 3 - 1/2 3.54 : 1 3 - 3/4 3.73 : 1 4 4.10 : 1 4 - 1/2 4.55 : 1 |
