![]() Join Date: Oct 2012
1966 front frame
It appears that the front of my frame is bent on my 66 c10 project. I replaced the radiator support as mine was bent.. Does anyone have a picture of a straight frame with no front clip on it?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
![]() ![]() ![]() Join Date: Jan 2018
Re: 1966 front frame
It's not a direct from the front shot, but it's all I sold the frame. Hopefully someone has a better picture for you
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() Join Date: Dec 2009
Check out Post#22 in this thread.
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=325736 Hope this helps ![]()
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
This will help for sure. Thanks
