02-19-2023, 08:37 PM | #1 |
Adding 2 more cylinders
I hate how my brain works sometimes. When I bought my 66 c10 and saw how well the 250 ran I had I long discussion with my brain that we will never have to swap out the motor. It's not fast but an inline 6 has a charm to it especially when most have been pulled in favor of their bigger cousins. But here I am anyway thinking how far a v8 is going to bury me financially. Back when I was a teen and didn't have two nickels to rub together I always did cheap rebuilds getting a $100 kit from summit and never having professional machine work done and hope for the best. They always worked but I cant do that anymore so do I find a crapshoot motor on marketplace, have it professionally machined, spend a thousand years gathering parts or do I get a crate engine? I have no idea what the going rate is for a block to be pro inspected and bored if necessary so I'm sitting firmly on the fence right now
02-19-2023, 09:35 PM | #2 |
Re: Adding 2 more cylinders
Prior owner of my truck swapped a used early '80s 305 small block into it, because running examples were cheap and easy to come by. If you don't need a hot motor, that may be an option without breaking the bank.
02-20-2023, 02:37 PM | #3 |
...just another truck junkie..
A basic crate engine is cheap (comparatively speaking) as opposed to buying a used engine and having it professionally rebuilt. I rarely mess with rebuilding engines anymore. If it's not something special I'll just get a crate engine.
Mike "Bear" Shea |
02-21-2023, 06:13 PM | #4 |
Before digging into options I would have agreed a crate engine would be considerably cheaper but I'm not so sure now. Summit sells a couple different brands like ATK, Blueprint and Edelbrock. ATK sells the last expensive option with remanufactured blocks and a basic long block with no intake or accessories ranges from $2500 - $3000 which I wouldn't be against but all of them are listed as unknown restocking date. Moving to next in line is Blueprint which for a mild drop in and go complete engine goes for $4500 - $5000. Salty but that includes carb, distributor, intake. I'd need a water pump and fuel pump to complete it and the blocks are new and not remanufactured. A plus in my book. Then theres the edelbrock engines which start at $5500 and go way up from there.......... I'm going to have to call a few local machine shops or pay them a visit to get a rough guesstimate on their prices because I could get a number of rebuild candidates for $200-$300
02-22-2023, 11:05 AM | #5 | |
Ask them availability of things you will need. Local machinist engine builder is selling of his equipement because he just couldn't get what he liked to use anymore. Blocks themselves were the first issue and I know lifters followed. Adam |
02-28-2023, 09:04 PM | #6 |
If you can drop by some shops that swap LS engines, they may have some good leads for you on perfectly good and complete engines that were pulled for a swap. Should be much less expensive and you could end up with a matching trans too.
02-28-2023, 09:23 PM | #7 |
Buy a newer Silverado with an LS, and swap everything over (engine, trans, wiring, ecu, etc), then part out what's left of the donor.
Getting an engine built is -always- more expensive, and there is always the stuff you didn't get with the motor that you need. And if you end up converting it to EFI, just buying a complete truck as a donor (that you can part out) is very wise.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
03-05-2023, 10:09 AM | #8 | |
I just had my truck out today on a good 20 mile run to stretch her legs for the first time since upgrading the points and lowering it and while it runs good I find myself wanting a bit more. the 250 runs great so far as I know, it was 30 deg this morning and I can lean in the window, give it a little choke and it starts right up first try. Out on the road is a different story as I can keep up with traffic in town fairly well but its still lacking a bit. I have to wind 3rd out past 3000 rpm before I can even think about 4th and when I do the least bit of a grade in the road has it whimpering. I can just feather the gas because anymore will have it spitting a bit. I don't know if its a timing issue, a carb needing a rebuild or if the 250 is just tired. |
03-05-2023, 10:40 AM | #9 | |
03-05-2023, 09:10 PM | #10 | |
I found a good carb rebuild that included rebushed throttle shaft and switching to a recurved HEI distributor made a world of difference on my six. Might be cheaper than an engine swap if it works. Of course best to do a compression/ leak down test first before you try to polish a turd😊. Then there is the whole gearing issue, which can drastically affect performance, but that’s a whole other discussion. Good luck Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
03-06-2023, 12:05 PM | #11 | |
