02-20-2023, 01:00 PM | #1 |
Control Arms Worth The Swap?
Factory '66 C10 frame and suspension
I'm building a simple budget driver and wondering if swapping the control arms to the 73-87 rubber bushings are actually worth it. I don't have the 73-87s so would have to track some down but other than being sorta easier to service is it a worthwhile upgrade? |
02-20-2023, 01:38 PM | #2 |
Re: Control Arms Worth The Swap?
It's also a good way to get front disc brakes, so if you were considering a brake upgrade, might make the decision easier. Search for "front cross member swap" - I think on the 63-66's you can swap either the complete front cross member or just the control arms and get the rubber bushings and disc brakes. There are a few threads on how to do this.. good luck!
02-21-2023, 10:04 AM | #3 |
73-87 arms are a downgrade, the rubber bushings go bad over time and allow deflection since they're rubber so they won't hold an alignment over bumps as well as the 63-72 threaded solid bushing design. I have a '66 with 150k miles that I took apart to redo all of the suspension and the threads on the control arm shafts/bushings looked like new and had zero play. My '74 C10 only has 43k miles and the rubber bushings are falling apart. There's a reason GM kept the 63-72 solid design on 3/4 and 1 ton trucks, they hold up better. The 63-72 bushings aren't hard to service, you just thread them apart. The 63-72 threaded design is better than aftermarket delrin/poly bushings; there is less friction so the suspension can move more freely and there is zero deflection.
You can add 73-87 balljoints to the stock arms if you want to use squarebody disc brakes.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-21-2023, 01:46 PM | #4 | |
02-21-2023, 04:48 PM | #5 | |
02-22-2023, 12:25 AM | #6 |
I 100% agree with Theastronaut.
I'm even thinking about switching my 81 over to the 63-72 control arms
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-22-2023, 04:04 AM | #7 |
http://67-72chevytrucks.com/vboard/s...d.php?t=727826 did this using only the late model spindles.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-22-2023, 09:52 AM | #8 |
All of my earlier trucks kept the threaded bushing a-arms if they were useable. The simple BJ swap allowed the disc brake improvement.
I did get one of the early/1st batch Ride Tech tubular arms when they first were released. They came w/the fatter car style 73-87 rubber bushings but by then there were Delrin style bushings out so that was my plan (stronger tubular construction w/the bind free Delrin bushings). Those arms got bolted onto a chassis that sat forever. I've had the dang things for prob almost 20yrs & they have zero miles .
