Old 02-22-2023, 06:52 PM   #1
rws1012
Terminal on side fill gas tank
Bought a side fill gas tank from LMC in 2021. Opened the box and installed it the other day. I got ready to hook up the gas gauge wire and found out there wasn’t a nut or any kind of way to hook up the wire. It is a stud. No threads.
LMC was no help at all. Has anyone else had a problem hooking a wire to this stud? Thanks for any help.
rws1012 is offline   Reply With Quote
Old 02-22-2023, 10:50 PM   #2
ray_mcavoy
Re: Terminal on side fill gas tank
Sounds like you might need a connector like this --> https://jcaparts.com/products/gas-ta...l-1962-1984-gm
ray_mcavoy is offline   Reply With Quote
Old 02-23-2023, 09:25 PM   #3
rws1012
Looks like that should work. I will give it a try . Thanks for the reply
Old 02-25-2023, 11:02 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Or - https://www.repairconnector.com/prod...-Pigtail-.html
