02-24-2023, 12:34 PM | #1 |
Active Member
LS swap in a 1978 K25 with a 4L80E
I am currently in the process of getting the body off the frame so it can be cleaned up and painted. I have two LQ4's, one complete with 160K and the other is fully machined and ready for re-assembly with flat-top pistons. I am leaning towards the fresh rebuild similar to an LQ9 with a Truck Cam. As is set things up, I know the engine can be placed in the "normal" position which is 1" ahead of where the stock SBC or BBC would be placed, or it can be set back that 1" so the back of the LS engine is where the TH400 that was in the truck would be placed. I also realize that the 4L80E is 1-1/2" longer than the TH400 and uses the same adapter for the NP241C (pass drop) t-case that I have for this project. I am using the 1985 and later "W" crossmember and short adapter.
For those of you who have put an LS in a Square Body with 4L80E, where did you end up placing the engine and what accommodations did you need to make for the transfer case? Thank you. Tom |
02-24-2023, 01:41 PM | #2 | |
Posted via Mobile Device |
02-26-2023, 02:54 PM | #3 | |
Active Member
Re: LS swap in a 1978 K25 with a 4L80E
Would still like to know from those that did this swap where they ended up with engine placement and other mods they had to do to the driveline. |
