Old 02-25-2023, 03:09 PM   #1
cdub2010
Door shutting adjustment issue
Im trying to line up my doors after some cab metal work. I have the body lines nice and straight but When I close the doors there is about 1/4 inch of free play in and out. It doesnt matter where I position the striker plate on the body, i can still push the door in too much. Shouldn't the door close tight without weather seals? The doors on my jimmy are rock solid when they close.
cdub2010 is offline   Reply With Quote
Old 02-25-2023, 03:22 PM   #2
72SB
Re: Door shutting adjustment issue
I would audition the rubber bumpers and weather strip (maybe just use an old piece on the striker side) to see if that resolves the free play you now have.
I played around with my striker an door latch plate quite a bit to get it all right. Now with the rubber in, its snug. I even have to slightly push the driver's door to lock with key. My sense is this will settle as the rubber conforms more to the door & truck. YMMV
72SB is offline   Reply With Quote
Old 02-25-2023, 04:17 PM   #3
Grumpy old man
Grumpy old man's Avatar
C10 Show Truck Project: Test Fitting Door Seals BEFORE Painting with Altman Easy Latches Installed / watch this video . It should help everyone .
Stout Custom videos on you tube .
https://www.youtube.com/watch?v=Zvw5RhbhPVc
https://www.youtube.com/watch?v=vZZQCcqOVCA
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-25-2023, 10:17 PM   #4
kaycee
kaycee's Avatar
Sounds like you got them about right, put door seals on and then adjust striker for tightness or looseness . If you want them tight before seals you will have to slam the hell out of door to shut after seals are on
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
