Old 02-26-2023, 01:43 PM   #1
Yamariv
Yamariv's Avatar
What are these solonoid looking things on my firewall for??
Hey guys,
I was redoing my HEI distributor power wire this week and noticed a second bundle of wires running to my engine that were not connected to anything. The HEI power wire bundle ran together with all the starter wires but this second bundle came from these solonoid looking parts on my fire wall and went to my engine for some reason.
I looked on the wiring diagrams but didn't have much luck, what are these wires for? Truck seems to run perfect without any of them hooked up..
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 02-26-2023, 02:44 PM   #2
truckster
truckster's Avatar
Re: What are these solonoid looking things on my firewall for??
TCS - transmission controlled spark. It was an early emissions device. You can safely delete it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-26-2023, 04:05 PM   #3
Yamariv
Yamariv's Avatar
Oh wow interesting!! So I can delete both of those little boxes?
Out of curiosity, how did that emissions system work?
3 Core Radiator
Old 02-26-2023, 04:13 PM   #4
Yamariv
Yamariv's Avatar
FYI, found this on another forum..
The TCS system was there ONLY for EPA emissions purpose. It did NOTHING for the engine, for economy, or for performance.
Basically, it retarded timing when the transmission (either manual or auto) was in lower ranges, but dropped out if the engine was either too hot or too cold and/or if WOT was employed. A retarded engine will run hotter in the combustion chamber and burn off more of the residual hydrocarbons.
3 Core Radiator
Old 02-26-2023, 06:45 PM   #5
truckster
truckster's Avatar
I've only seen TCS systems with a single relay. Can you move the black wire loom so it's easier to see what's going on there?
Old 02-26-2023, 07:55 PM   #6
Yamariv
Yamariv's Avatar
Took some more pics from different angles for you, hope it helps!
3 Core Radiator
Old 02-26-2023, 08:47 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
The TCS relay has dark blue and dark green wires to it. The other item is not part of the TCS system.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 02-27-2023, 01:09 PM   #8
Yamariv
Yamariv's Avatar
Dang, any idea where I could find out what the other relay is for? Wiring diagrams maybe? I'd really like to get rid of that whole second harness..they arent connected to anything right now
3 Core Radiator
Old 02-27-2023, 02:06 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, Looking at this wiring diagram, that says (O2 only), if I'm reading it right. That's an 18 ga tan wire on it. Up near the top right it shows heater blower power (Except O2). I'm drawing a blank, maybe someone with more electrical knowledge can point you right. Does your heater blower work?
~Steven
Simi Valley, CA
Old 02-27-2023, 08:12 PM   #10
Yamariv
Yamariv's Avatar
Gah, I'm not too good at reading those electrical diagrams either. Yes, the blower motor works but only on a low setting, maybe it's medium I can't tell. Where do you see that tan wire going to a blower? Fixing the blower motor switch is on my list. Lol
3 Core Radiator
Old 02-27-2023, 08:42 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, I don't know what "O2" means. But it does seem to indicate some difference in the heater blower motor wiring. Many times when I get into the nitty-gritty details with things like this on the internet, it seems like I get it wrong, so I want someone with more experience to weigh in. If I had the truck in front of me, I'd be able to figure it out.
~Steven
Simi Valley, CA
Old 02-27-2023, 10:12 PM   #12
Yamariv
Yamariv's Avatar
Sounds good, hope someone chimes in! :S
3 Core Radiator
Old 03-02-2023, 08:22 PM   #13
Yamariv
Yamariv's Avatar
Just a quick thread update.. I posted in the electrical section but didn't get any further info on the second solenoid so I decided to remove the whole harness and solenoid setup and see if the truck still runs. Yup, ran fine, both these solenoids can hit the junk pile incase someone is wondering about their truck. These are just for the TCS emissions system.
Engine bay looks much cleaner now and I only have one harness running to the engine. Woohoo
3 Core Radiator
