02-26-2023, 06:44 PM | #1 |
jeep doorstop
Who all has done this mod? is it still holding up? reviews on amazon aren't very reassuring
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
02-26-2023, 06:57 PM | #2 |
Re: jeep doorstop
I used jeep fronts, but wasn't happy with the reduced "opening," so I ended up removing the rubber stopper. Happy with how it works.
Had some issues with the factory roll pins not staying put, so I've changed them to a screw and nyloc nut. Might be a #10 or #12 or 1/4" or whatever fit. Truck has zero miles, and hasn't even run yet.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-26-2023, 07:04 PM | #3 | |
Re: jeep doorstop
They worked perfectly, but I removed them as it reduced the door opening too much for my liking. |
02-26-2023, 10:48 PM | #4 |
Re: jeep doorstop
I put ones from the front door of a Jeep on my 63. I cut the rubber bumper into three even pieces, then reinstalled everything with one of those slices. I believe the door opens to just about what the factory ones do, and there's still a little cushion for the checks to bounce on.
They work so much better and I absolutely love not having the door close on the back of my legs anymore. I was able to source two original ones from a junkyard Jeep, so I have no experience with the aftermarket ones
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-27-2023, 12:35 AM | #5 |
Re: jeep doorstop
I cut my rubber bumpers in half. Opens up to about normal... I'd be interested to see how much the doors open with it completely removed or cut into thirds.
02-27-2023, 12:44 AM | #6 |
Re: jeep doorstop
With no bumper, I believe there is plenty of room before the door could the cowl.
I cut them in half at first, tested, and then just removed them.
02-27-2023, 03:25 AM | #7 |
Re: jeep doorstop
Woody came without a door check on the drivers side so doing the Jeep upgrade was a no brainier for me here in the UK as couldn’t get an original.
As others have said, if you leave the original rubber stopper in place the doors don’t open very wide, I cut mine in half as others have done, but have now taken the rubber out entirely, works fine. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
02-27-2023, 10:06 AM | #8 |
Re: jeep doorstop
What year Jeep do you need to look for to get the correct stops? And is a Jeep Wrangler?
02-27-2023, 11:22 AM | #9 |
Re: jeep doorstop
http://www.persh.org/pickup/DoorChecks.htm
Here you go. I too sliced the rubbers to half the thickness for more opening. |
02-27-2023, 04:50 PM | #10 |
Re: jeep doorstop
I did this with mine. It was so long ago that I forgot if I used ones from a cherokee or a grand cherokee. It matters. I also had to do a little grinding on the rod. But I don't remember why. There are a couple of threads on here that give a good explanation of what you need exactly. Just do a advanced search.
02-27-2023, 04:54 PM | #11 |
Re: jeep doorstop
These two threads should help
http://67-72chevytrucks.com/vboard/s...d.php?t=446066 http://67-72chevytrucks.com/vboard/s...grand+cherokee |
02-27-2023, 10:27 PM | #12 |
Re: jeep doorstop
It's been a while, but I believe the rear door checks are longer then the front ones. I know I have a set somewhere. Where, well who knows.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-27-2023, 10:45 PM | #13 |
Re: jeep doorstop
Ignore this
03-12-2023, 05:48 PM | #14 | |
Re: jeep doorstop
https://lugnutz65chevystepside.weebl...ry-simple.html JEEP DOOR CHECK DIY
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
