Steering shaft 1 piece vs 2 piece
I bought an original non-tilt steering column to replace the one that came in my ‘70 c10, the one in the truck was missing a lot of stuff. The one in my truck came out of a ‘68 so the steering shaft it one piece from the steering wheel to the steering box with a rag joint connecting it. The “new” column came out of a ‘70 which would have been a 2 piece shaft. I have the top half but not the lower half that connects to the steering box. My question is, what is the benefit of the 2 piece shaft? Would it be worth hunting down the lower part I need or should I just stick with the 68 shaft in the 70 column?
Posted via Mobile Device |
Post Whore
![]() Join Date: Feb 2016
Re: Steering shaft 1 piece vs 2 piece
The 2 piece shaft is safer in front end collisions. Less chance of the steering wheel getting shoved through your chest.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
68 C10 Longbed
I have a lower shaft (Intermediate shaft) if you need one let me know.
![]() Join Date: Jun 2005
The 67-68 columns are also 2 piece they just don’t have the spring in the middle. Look closely at the shaft above the tag joint and you will see 2 shear pins. They are hard to spot but they are there.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
68 C10 Longbed
When I changed my 68 standard steering column to a tilt column there was also just a long shaft with no intermediate shaft. Then I received my tilt column and it was short with a splined end and I had to find an intermediate shaft to connect it from column to rag joint.
![]() ![]() Join Date: Jan 2005
Having the intermediate shaft with the joint in it makes it easier to remove and install the column. The non-bending 67-68 shaft makes it a real pain to maneuver the column through the hole in the firewall.
#8 | |
![]() Join Date: Oct 2020
68 C10 Longbed
My 68 definitely does not have an intermediate shaft. I had a column shift 3 speed manual column and it was not a two piece. I have or had a solid steel rod that goes straight through to the rag joint (Original truck). When I switched to a floor shift tilt column I needed to find the intermediate shaft which I was able to do (Found Used) and it was installed so now I do have two piece. So some do and some don’t. This may be 67 & 68 only not sure.
