Old 03-01-2023, 03:39 PM   #1
cj847
cj847's Avatar
Steering column what did I do wrong
1967 automatic non tilt column.
I disassembled it and replaced the upper and lower bearings. Reassembled and everything seemed fine. But, for lack of a better description, the shift tube is not returning. Basically, there is no safety to keep from pulling it out of park. It was working before disassembly.
There are not many moving parts to this assembly, but I can't figure out what is wrong. It seems almost impossible.
Also, it seems "tight" when moving the shift lever, especially out of park. Any ideas?
cj847 is offline   Reply With Quote
Old 03-01-2023, 04:07 PM   #2
cj847
cj847's Avatar
Re: Steering column what did I do wrong
Some pics
Old 03-01-2023, 04:17 PM   #3
ochremo
ochremo's Avatar
The locknut where the trans linkage fastens to the column could be too tight.
ochremo is offline   Reply With Quote
Old 03-01-2023, 07:17 PM   #4
HO455
Post Whore
HO455's Avatar
This thread should help. Look at the photos of the detent mechanism at the base of the column, I believe that is where your problem is.
http://67-72chevytrucks.com/vboard/s...d.php?t=491049
RIP Bob Parks.
Old 03-01-2023, 07:55 PM   #5
cj847
cj847's Avatar
Thanks for the comments. I do have an update to my earlier post.
1) The park lock position has been broken off. I had not noticed that before. I guess I always pulled up to shift. But anyway the "hard to pull into gear" remains. The first gear stop is about all that is left of my detent mechanism.
2) Today I loosened the preload on the lower bearing hoping that was the problem. It was not.
Old 03-01-2023, 08:48 PM   #6
HO455
Post Whore
HO455's Avatar
The spring clamp on the bottom can make the shifter movement hard and it is not easy to get it set correctly. I used a clamp and vise grip so I could control the movement of the clamp on mine when I replaced the steering box and rag joint on my Burban.
See link below and scroll to post 849 to see photo of clamps with additional information on the next page
I hope this helps.
http://67-72chevytrucks.com/vboard/s...698377&page=34
RIP Bob Parks.
Old 03-01-2023, 10:09 PM   #7
pjmoreland
pjmoreland's Avatar
The cylindrical piece that mounts at the bottom of the column and houses the lower bearing has some adjustment to it. The screws that attach it to the column pass through a band and some slots that are at an angle. With the screws loose, you can rotate this assembly to either increase or decrease the clearance between the detent plate and the arm that the shift rod connects to. If there is inadequate space between the detent plate and arm, then they could be binding up on each other.
pjmoreland is offline   Reply With Quote
