Old 03-01-2023, 05:35 PM   #1
SoCoC10
SoCoC10's Avatar
Any SPID experts that can help with this?
I purchased a 1970 K5 Blazer and here is what is left of the SPID. The SPID VIN number does match the VIN on the door jam. Thanks in advance for any help with the info on the damaged right column.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 03-01-2023, 05:59 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Any SPID experts that can help with this?
By chance does the truck still have its build sheet? Between that and some SPID references you can remake one.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-01-2023, 06:50 PM   #3
SoCoC10
SoCoC10's Avatar
No the interior is gutted. No build sheet.
Old 03-01-2023, 08:57 PM   #4
c10sport
c10sport's Avatar
This will help with about 2/3rd's of them.
https://www.gm.com/content/dam/compa..._Full-Size.pdf
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 03-02-2023, 08:37 AM   #5
I don't know what to say about the missing codes. I'd say build it as you please and have a SPID made. At this point the Blazer is beyond authentication. I wonder if the glovebox door is original and the body was replaced or the opposite. My guess is the SPID was torn of because of the mismatch. But It's odd that the VIN was left to be seen
Old 03-02-2023, 10:59 AM   #6
A1971Blazer
A1971Blazer's Avatar
Try to determine what it actually has on it....the rest you'll have to guess at.
Look here for option codes www.outintheshop.com This guy will make what you want and send a preview
also look at other SPID labels from the same year to determine the code and description.
Here's one from my '70 that I had reproduced...I changed the interior code from the original blue to black....all others stayed the same.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-02-2023, 06:20 PM   #7
I see a Z, which is likely Z84 CST
Old 03-02-2023, 09:21 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Two "Z"s, so maybe gauges? Easy to check. "M4" something is probably M49, THM trans.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-02-2023, 11:07 PM   #9
c10sport
c10sport's Avatar
Post good detailed pics of the truck and maybe we can narrow some down further.
I went through the Blazer SPID thread and the others are from my own research on SPIDs for the past 35 years.
MODEL= KE105014 (2WD is CE10514) - unreadable but is probably a seat code, very likey "4A53AC Rear Seat Equipment (if so equipped)
4F60AH Heavy Duty Front Springs - Unreadable (could be A11 tinted glass, A09 frameless glass, A50 bucket seats, B93 Door edge guards, F76 free wheeling hubs, BX2 body side mouldings who knows)
4J70BW Brake Booster Equipment - 4K???? *there are only a few K RPOs available in 1970, Could be K30 cruise control, K05 engine block heater)
4K31AA Manual Throttle control - 4K???? Generator code either K76 61 amp or K79 43 amp
4LS9BD 350 Cu. In. V8 engine - 4M49JA Turbo Hydra-Matic
4N40BR Power Steering - 4RR2??(likely AB) 10x165x6 FRT RR&SP (tires)
4T60AA Heavy Duty Battery - 4U???? could be U29 courtesy lamps (looks likely), U16 tachometer
4U63BA Radio Pushbutton - 4Z53TC(guessing) Ammeter-oil gauge
4Z58AA Auxiliary top-white - 4Z84ZJ (most likely code) Custom Sport Truck
4524AA Hugger Orange - 4????? Interior code, have to see your interior
That's what I've gathered. Probably isn't 100% accurate since I am more familiar with squarebodies but pouring over the RPO list on GM's website, the Blazer SPID thread and a brochure, I'd say I'm 96% accurate. As I said, pictures would likely help nail down the unknowns and you can get a replacement.
Jay
Old 03-02-2023, 11:44 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ Wow, that's amazing! Well done, even if some are only guesses. Way more than I got out of it.
~Steven
Simi Valley, CA
