Old 01-06-2004, 08:51 PM   #1
mkmathis
98 Suburban 4WD gone out?
I have a 98 suburban and when I went to shift into 4wd the light on the floor diagram did not come on and 4wd is not working. Has anyone encountered this or if you even have a guess Iwould appreciate it because I dont know where to start looking.
mkmathis is offline   Reply With Quote
Old 01-06-2004, 09:04 PM   #2
ozarkhippie
Check to see if the solonoid (sp) on the front axle is working, most of the time it goes bad.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 01-06-2004, 09:10 PM   #3
ozarkhippie
forgot there is also a fuse.
Buy Sale or Trade
71 3/4 4x4
Old 01-06-2004, 09:11 PM   #4
mkmathis
I will start with that.
THanks
Old 01-06-2004, 09:12 PM   #5
mkmathis
Fuse in dash, right? and how do you check the solenoid?
Old 01-06-2004, 09:20 PM   #6
ozarkhippie
the fuse is in the dash. check with a test light to see if there is current at the sol first, if not check the fuse, . If there is current the sol. is probally bad.
Buy Sale or Trade
71 3/4 4x4
Old 01-06-2004, 10:40 PM   #7
mkmathis
Thanks!
Old 01-07-2004, 01:12 PM   #8
Scrub
Collector of rusty Items
Scrub's Avatar
Dang,
I hope you figure yours out easier than mine.
Check the fuse in the left side of the dash hidden by the driver's door. I.e. Open the door and look for the little cover. I think there are two fuses fo 4wd.
If you blow the fuse,
Mine had two broken wires that took like 5 months, $3000 and 7 trips to the dealership. The Dealership can look at your error codes and maybe tell you what the problem is. After that, you just start replacing parts.
Here is the order that I came up with:
1) Engaging solenoid in front axle, the new part has a cylindric spacer about 1.25 inches in diameter and 1.5 inches long. Make sure you have one and only one as this is an addition and some folks have added two. $125.00
2) Transfer case engagement motor and gear drive, $545.00
3) Computer for 4wd $575.00
3) Dash switch $175
4) rebuilt t-case $1800
Then you find the broken wire.... !
5) divorce because your wife's damn car won't work after 3K $100,000.00, your house and allimony, but you get to keep the suburban!
6) "Accidental" fire in 2wd suburban, 3 years in jail
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
