![]() Join Date: Nov 2022
69 column w/o tilt parts help needed
Once again what I thought would be simple is made difficult by parts searching. I am at my wit's end! Need to find a vendor or sells OEM or OER.
Restoring a 69 C10 (K10) non tilt, floor shift only column and have been stuck for a week trying to locate 3 little parts without luck. Not broken or wore out by any means but since I have it blown completely apart for paint, I thought I would replace everything consumable. Can reuse if no vendor found. Parts needed: Upper column bearing holder (manual just calls it a washer) and rubber washer that attaches to it. Lower column white plastic bushing. Any help would be appreciated. |
![]() ![]() Join Date: Jan 2005
Re: 69 column w/o tilt parts help needed
Here's the lower one:
https://www.ebay.com/itm/12526640170...Bk9SR66FyqHVYQ The other two parts are unique to the floor shift column. Might be difficult to find. I can't find them in the parts catalog. http://67-72chevytrucks.com/vboard/s...d.php?t=827926 Seeing as how the housing that sits between these bushing never rotates, I wouldn't expect them to ever wear out. |
#3 | |
Always on the hunt...
![]() Join Date: Sep 2006
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=838093
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
#4 | |
#5 | |
Thanks |
We just posted some pics and details in that above linked steering column parts f/s thread, have a look and let us know. Mel
![]() Join Date: Apr 2010
In your 1st picture you are calling the white bushing a lower column bushing when fact it is the lower bushing that is in the top of the column that should have a metal washer underneath it, the part you have high lighted in yellow in the 1st picture is the top of the column, hope this helps
Good eye, you are correct.
I should have worded it better. Unfortunately, they are above and below each other in close proximity and have the same names per the manual (washer/bushing) so I described them as upper and lower to try and get my point to register. I guess just showing the picture may have done the trick for most. Thanks for the response as I would not want others being confused when doing any parts search. |
Photo just to clarify in case I confused anyone
The Older Generation
Look at this thread. It covers a lot about those parts..... http://67-72chevytrucks.com/vboard/s....php?p=4755990 LockDoc
Last part found thanks to Classic Bowties great selection of OEM parts.
![]() Join Date: Jul 2000
Great forum, huh? Having owned my 69 C10 for more than 30 years, I know a lot about it, but I still come here for help...and get it!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#13 |
FYI on the lower bearing and ring for the 69 column w/o tilt.
I have rebuilt several tilt columns and a few w/o tilt and never had to replace the "ring" or what some people call the lower bearing housing/assembly. I just happened to order a lower bearing from Classic Parts that came as a set (bearing, ring and spring) for the same price as I could get the bearing alone so I bought it. Upon receipt, I noticed the ring was about a 1/4 " shorter than the original and that the bearing would not fit inside. However, the bearing would fit inside my original ring and both bearings looked identical. Looking at the new ring, the opening tapers in at about 30 degrees whereas the original just drops straight down. Also, the spring is much different than the original. I contacted Classic Parts and they said they have sold over 100 with no complaints and that other vendors were selling the same kit. Anyone else notice this???? Something aint right! Luckily all I need is the bearing and the ring with make a great paper weight in the shop. Should have just bought the bearing and I wouldn't be here clicking away. : ) |
#14 | |
#15 |
Lived and learned. Will definitely check your inventory before I order future parts. Your NOS selection is remarkable.
