Old 03-04-2023, 08:12 PM   #1
master 1969 c10
Active Member
Where does this spacer go
Hi guy took out my resr end and forgot witch side this spacer went thanks for your help I also have a pinhead drop bar on it and a no limit shock relocation kit on it they may help
master 1969 c10 is offline   Reply With Quote
Old 03-04-2023, 08:28 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Where does this spacer go
Can't tell without out knowing how wide x length but if it came from your rear axle it was placed there to correct alignment of the bed . Chevy twist , It shouldn't be there if the frame is stright ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
