![]() Join Date: Jan 2016
C10 master cylinder plumbing
Which master cylinder port is the front brakes on a 1967 C10 with power disc/drum conversion? I have read that on a standard C10 the port closest to the firewall is for the front brakes, is that true. If that is true the PO plumbed this thing wrong. Also note the small size of that front line.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
Re: C10 master cylinder plumbing
FWIW my CPP MC/Booster for a disc drum 72 (was a non power brake disc/drum truck) my front brakes are forward reservoir and rear drums the rear reservoir. Also the front lines are thinner than rear brake hard line....just like your set up
Not sure what donor or kit you have but suspect it would be the same. |
#3 | |
![]() Join Date: Nov 2013
I have 2 K/5 Blazers and 2 C10s...the front port (bottom) is for the front brakes, the rear port is for the rear brakes on all of them. they all have disc/drum
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
All those posts I read about k10 and c10 being backwards came off this site. I am so confused!!!!!!!!! Makes sense since every picture I see of the PV plumbed to the MS has them plumbed that way.
Front disc brakes use more fluid than drum brakes...
As the brake pads wear, more fluid is found in the calipers. As drum brake wheel cylinders operate, springs collapse the wheel cylinders and push the fluid back to the master cylinder. Thus you should find the larger reservoir going to the front. Bob |
![]() Join Date: Apr 2016
I believe it is C20's that have the front reservoir going to rear brakes, and on C10's the front reservoir goes to the front brakes. It is the C20's with the swapped plumbing that causes confusion in my opinion.
The disc brake reservoir should be larger than the drum brake reservoir. For C10's the bore size is 1-1/8 inch for manual or power brakes. Manual brake master cylinders have a deep pushrod hole, while power brake master cylinders have a shallow pushrod hole. Here is a thread with the master cylinder technical info and other good info, including some example C20 info and pictures mixed in. https://67-72chevytrucks.com/vboard/...30#post8909230 But I don't know if there is a right and wrong for the arrangement on a truck that has been converted to disc brakes. If there was a right or wrong, I think your truck is right in my opinion. I have a C10 71-72 pre-bent tubing set from Inline Tube on my 1969 C10 that has spindles and brakes from a 1971 donor truck, and a manual brake master cylinder. Here's what it looks like, very similar to yours. - |
#8 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Thanks guys I feel confident mine is plumbed correctly now.
![]() Join Date: Jul 2000
My 69 has a 71-72 booster and master. Front reservoir is for front brakes. For the type of master cylinder you have, the rule of thumb is the larger reservoir is for front discs.
For whatever reason, GM used 1/4" brake lines on the rear.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
